Fluid MotorUnion C32 AMG Teaser
Rating: Thread Rating: 12 votes, 5.00 average.
Old 01-27-2010, 07:55 PM
jturkel's Avatar
02 C32 AMG
Originally Posted by moosejaw
so ur using the Code 3 pulley with the 185?
I didnt think it was even possible???
But nice pics
Look fwd to more
he has larger intake plenums.....so less boost, shifts efficiency of supercharger, and he can run both pulleys....and has the proper fuel setup with larger injectors and pump
to fluidmotor:
can you provide some more information about your dual BMC intake thing? cost? gains? gains compared to other intake setups? does it only work with the larger tb?
also, where do you sit at with your overall delta over stock?
Old 01-28-2010, 12:54 AM
02C32guy's Avatar
2005 E55
This is worse than the first teaser pic. I need numbers! Pleeeaaasseee.
Old 01-28-2010, 09:10 AM
RLx02's Avatar
C55
beautiful welds/exhaust system!
Old 01-28-2010, 11:04 AM
Biscuit's Avatar
'03 C32, '08 ML63
Originally Posted by FluidMotorUnion
Coolant Tank Reservoir with silly FMU writing to be revised (CNC Issues)
Nice.
Like everyone else I'm curious how you got the stacked pullies to work out. All the other attempts have produced less than desirable results. If I'm not mistaken several people encountered issues with the MAF sensor as well throwing up CEL's.
Old 01-28-2010, 12:53 PM
ZAHANMA's Avatar
'13 Dodge Dart, '16 Audi Q5
I know FMU is stating it is a 185mm pulley. However, I did not know that ASP made 185mm pullies? I am very interested in all this if it is in fact a 185+C3 stacked system. The only pulley that ASP shows for the M112K is 14% Overdrive Crank Pulley <<LINK which would be a 178mm ASP Pulley.
If it is a 178mm pulley, then I am less intrigued as several SRT6 guys have been running this for some time.
Either way, nice build and the intake looks interesting. Now I just need to upgrade my injectors and fuel pump... Can't wiat for spring.
Looking forward to hearing more about this.
Old 01-28-2010, 06:23 PM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
Interesting observation. Can't comment on this particular pulley, but AFAIK the indirect answer to question of "does ASP make 185mm pullies?" is "as a pulley manufacturer, ASP will make whatever pulley you want."
A few of the 55 Kompressor owners have allegedly requested ASP make them custom-sized crank pullies (perhaps even as large as 190mm) which, from what I gather, ASP can accommodate at the client's request. So, my guess is that FMU spec'd a custom 185mm crank pulley from ASP for this build - but I'm sure FMU can clarify for everyone.
Still want to see dyno sheets.
Old 01-28-2010, 11:30 PM
  #32
ZAHANMA's Avatar
Good point. This does make perfect sense. I just didn't think they would go out and get a custom pulley for their first full MB build.
Old 01-28-2010, 11:53 PM
  #33
SilverBulletAMG's Avatar
C32 AMG
The car looks fantastic...inside and out! Can't wait for dynos, time slips, more pics, and more details.
Old 01-29-2010, 07:34 PM
  #34
02C32guy's Avatar
2005 E55
I'd also really like to see a pic of the front part of the intake where it goes through the radiator support. The whole things looks and sounds awesome though. Good Job guys.
Old 01-30-2010, 06:46 PM
  #35
robbinghood's Avatar
all of them
74 lbs injectors? That seems like 30 lbs/hr too much. Unless the motor is pushing like 30 psi and 700 RWHP+!!!
Good build. Curious on numbers. I've seen a similar stacked pulley, fuel system, intake, and exhaust car put down 400 RWHP.
Old 01-31-2010, 09:35 PM
  #36
aleksandar1099's Avatar
Mercedes
Awesome looking project! Great work as always!
Old 02-01-2010, 09:37 AM
  #37
Biscuit's Avatar
'03 C32, '08 ML63
Dyno? Numbers? Bueller?
Old 02-01-2010, 06:57 PM
  #38
AJBoost's Avatar
C32 AMG, Trans Am, Lincoln Navigator, E36 325i
Love the "blacked out" theme.
Old 02-02-2010, 04:46 PM
  #39
Former Vendor of MBWorld
FluidMotorUnion's Avatar
A few
Still working with the file guys!
So far 350whp, we're thinking this will be right around where it stays but we will see!
-FMU
Old 02-02-2010, 05:00 PM
  #40
Dingleberry's Avatar
Marsaydees
-FMU
should be decent for overtaking people on the highway
Old 02-02-2010, 05:26 PM
  #41
SPONSOR
loungn14's Avatar
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
-FMU
Nice job guys....about time you showed what you were working on!
Old 02-02-2010, 05:30 PM
  #42
jturkel's Avatar
02 C32 AMG
350 seems kind of low with all those mods.
what kind of dyno are you using? and what was your baseline? its all about the delta.
and can we pretty please get more info about the intake setup? looks sick!
Old 02-02-2010, 11:18 PM
  #43
silentkiller's Avatar
c280 w202
Good Quilty Work. That is what i like to see.
Old 02-02-2010, 11:30 PM
  #44
albanianbenz's Avatar
2004 S/C M3 Vert, 2004 E55
they have a dynodynamics not a dynojet, so #s are usually a bit lower on those.
Old 02-03-2010, 12:55 AM
  #45
jturkel's Avatar
02 C32 AMG
yah, those numbers are still low. my numbers on 91 octane are higher on a dyno dynamics and i have less mods (i do not have stacked pulleys, larger tb, p/p intake plenums, larger injectors, larger pump, coolant tank reservoir (keeps IATs down = more hp))
that is why i'm inquiring about the baseline dyno so i can see what the overall delta (change in hp over stock) is.
Old 02-03-2010, 01:05 PM
  #46
A few
Hang in there!
Old 02-03-2010, 01:14 PM
  #47
jturkel's Avatar
02 C32 AMG
Hang in there!
very impressive whp delta = 85.4 whp.
baseline tq seems a bit low, but current number looks solid (peak 378wtq?). nice broad tq curve.
keep us posted!
Old 02-03-2010, 01:31 PM
  #48
A few
keep us posted!
I apologize for the “road speed” graph but baseline dyno’s were taken with ignition tacho while these last few runs were taken via “roller tach”. As soon as we sort out to final file we will make sure a proper graph is posted showing a 5252 crossover for each run.
Old 02-08-2010, 04:24 PM
  #49
Newzchspy's Avatar
PLAID
Any more updates on this since last week???
Glenn
Old 02-17-2010, 04:18 PM
  #50
02C32guy's Avatar
2005 E55
I guess we haven't heard any news because you're busy doing this:
http://jalopnik.com/5473181/fireball...lambo/gallery/
Pretty damn cool though.
You have already rated this thread Rating: Thread Rating: 12 votes, 5.00 average.
Quick Reply: Fluid MotorUnion C32 AMG Teaser
