ODPS installed overseas.
Old Mar 16, 2003 | 08:06 AM
Shine's Avatar
Thumbs up ODPS installed overseas.
Thanks for Evosport's delievery.
Well written manual & precisely parts packed.
About the installation, here is my observation
(1) I have stainless engine bay underhood (option of W203)
the mechanic cut a hole to pass the pipe connect to the
bottom of windshield wash reservoir.
the plastic standard underhood maybe a little easier.
(2) We use coolant instead of water here.
I'll hand made one to keep the windshield wash function.
which is water only.
(3) I removed the heater to facilitate the installation.
& no problem here in Taiwan.
How's that in the states ? do u keep it anyway ?
I can "feel" the boost up .......
Old Mar 16, 2003 | 02:57 PM
SiLvaC32's Avatar
C32
nice! which shop did you do it at? do you know big bear from J's racing?
Jerry
Old Mar 17, 2003 | 02:12 PM
Pierre32///AMG's Avatar
Porsche Turbo Stage 4, Cayenne S ... gone C43, C32, ML55 & Ducati 999.
Sweet!!!, now let see how well the C32 goes..... please feedback, and comparations at the road before and after.
Old Mar 17, 2003 | 03:26 PM
DL_AMG's Avatar
2011 C63, 2004 S500, 2013 E350, 2013 Ody Elite
I will like too see...
Your CLK50K kills your new mod C32 again. :P
By the way, Shine, do you know the person who got into accident few days back with his GF in his Lotus V8TT in Taiwan? There maybe less than 10 Lotus have been imported to TW. The engine seems to be perfectly fine but the front & Roof was pretty much GONE.
Old Mar 17, 2003 | 06:04 PM
tango's Avatar
pics shine pics
Old Mar 17, 2003 | 07:09 PM
Shine's Avatar
Smile
Thanks guys !
I know that accident by TV, a Lotus elise crashed
Kids always did that before they're familiar w the BORROWED car.
The owner lost a friend & a Lotus both !!
He's guilty, IMO.
Back to the status update
(1) The 2nd C32AMG will take pics of installation.
I'm the pilot & 8 hours took to finish it. :p
(2) Daimler Mercedes chief mechanic take care the installation.
He's in charge of Kleemann upgrade (> 50 cars) & conduct Brabus SL55 K8 upgrade,an expert of MB vehicle tunning.
there're three more to go ODPS here in Taiwan soon.
(3) I read 100 C !! coolant temp after hard driving in mountains
u know,it's less cooling effect than highway flying.
(sorry to use C instead of F)
Is that high temp normal ?
Do u know the reasonable range of coolant temp ?
CLK50K has never over heat to 92 C whatever hard driving it.
We'll reset the trigger temp of cooling fan as a result.
Old Mar 17, 2003 | 07:55 PM
Vadim @ evosport's Avatar
C32 AMG
Shine: Make sure your mechanic has refilled coolant overflow. That is the only thing I can think of why your coolant temp might be high. We have not had any cooling problems.
Old Mar 18, 2003 | 12:14 AM
Shine's Avatar
Vadim :
Both reservoir of engine & bottle for I/C are filled coolant correctly.
Do u remove the heater of windshield wash bottle ?
Old Mar 18, 2003 | 11:40 AM
C32 AMG
Shine: Yes you can disconnect the heater.
As far cooling, make sure your mechanic has bled the cooling system.
Old Mar 18, 2003 | 07:47 PM
Shine's Avatar
Smile
Few upset news from members in the states.
Missing pulleys or installation guide ?
I'm wondering anyone out there are trying to "copy" your product
just my guess, hope you can clarify the issue.
We paid for Evosport's R&D & times of test .... for knowledge.
They should not be copied EXACTLY elsewhere by cheaper price.
p.s Glad to know the missing pulleys has been post shipped.
Old Mar 19, 2003 | 04:18 AM
bverotti's Avatar
C32
My mechanic has some questions regarding the connection of the hoses.
The IC coolant reservoir (not the windshield reservoir) has 2 connections (your pict 1 in the manual). Standing in front of the car, one connection is in the front and the other one goes out to the right. According to your manual the front connection gets detached and the hose is closed using the male and female plug. This hose however leads to the IC core where it also gets disconnected and further leads to the return circuit where it also gets disconnected. It seems like you can take out the hose completely and there is no point closing it if you are going to take this hose out completely.
Second question. Again the IC reservoir has a connection on its right side : what is it used for ?
My mechanic also has questions about putting wind shield washer in the cooling system. Since there is some cleaner in the weather he thinks it might start to 'foam' when it gets heated and create air bubles in the cooling pipes.
Old Mar 19, 2003 | 07:34 AM
Shine's Avatar
Exclamation
Another advice from My mechanic about the heat problem.
Reset minus 5 degree C cool fan trigger temp than factory setting
He did that for Kleemann cars as standard.
1. Two of us read coolant 100C after installation.
-5 C fan startup, any comment ?
2. All of us miss #5 pulley, hope to receive it soon.
Old Mar 21, 2003 | 12:04 PM
Shine's Avatar
Smile
Status update
(1) Replace the stock filter with BMC filter, the softer frame
seal better than hard framed K&N filter.
(2) Reset the fan -5 C start, the coolant temp reading range
80~90 C, much cooler than factory setup around 95~102 C.
(3) Set feul stage-II 10% richer than standard
Go for test run
I can feel stage-II do response a little better in torque !
(4) Hand made a windshield washer bottle, filled w/water
hook it up above the ODPS S/C cooling bottle.
Two of us here have installed ODPS, two more to go.
All of us are waiting #5 pulley, they're on the way.
Old Mar 21, 2003 | 01:31 PM
C32 AMG
Shine: Sorry about #5 pulley. My wife went into labor on the same day and the shipper was not aware what goes into ODPS set. #5 is on the way to you next day FedEx.
Bverotti: We leave the hose in the car in case you want to take it back to stock.
I am not sure about your second question. Can you e-mail me a picture? Thanks.
Old Mar 21, 2003 | 05:25 PM
box986's Avatar
W211 E63
Vadim & Ben:
Where is my #5 pulley, I was "suppose" to get it Friday(today)?
Old Mar 21, 2003 | 07:15 PM
Mach430's Avatar
According to FedEx, it has been at your home since 10:36 this morning.
Old Mar 22, 2003 | 09:35 AM
Shine's Avatar
Smile
I notice improvement in low rpm torque, 1500~2000 rpm
plenty of torque burst out at very lower rpm, that's the
feeling I enjoy.
I'm very happy to cruise the C32 w/ODPS in highway, effortless
accel by its stronger torque than before.
It's now a step closer to a powerful V8 cruiser
Yes ! We're highly interested in V6 headers,too.........
The dealer import a few W203/V6 headers from Supersprint, I'd like to reference headers from Evosport.
Old Mar 22, 2003 | 12:14 PM
Mach430's Avatar
Supersprint does not currently offer any headers for the V6 w203 models. They do offer them for the C200k, but you have a slightly bigger engine...
http://www.mitcom2.com/supersprint/a...?gruppo=mer203
Old Mar 29, 2003 | 02:12 AM
box986's Avatar
W211 E63
Vadim:
Thanks very much for the tip on installation of the ODPS, everything went easy after the cooling fan was removed..... it took me and my tech less than 4 hours total
:p :p
Old Mar 29, 2003 | 03:44 AM
Mach430's Avatar
How does it feel? Let us know once you get 100 miles on it!
Old Mar 30, 2003 | 06:51 PM
Shine's Avatar
Smile
Originally posted by Shine
(1) Replace the stock with Hi-flow filters,I use BMC filters.
(2) Down set the fan -5 C start, the coolant temp reading ranges from 85~92 C, pretty normal w/additional boost.
(before 92~102C)
My suggestion for ODPS users.
Old Mar 30, 2003 | 08:43 PM
box986's Avatar
W211 E63
I already had my fuel setting at "93" instead of "base" but I think that actually adjusts the ignition timing not the fuel enrichment!
As far as feedback goes,,, horsepower is addictive and I felt about the same as stock already(maybe I am already used to it), hehe.
So keep the mods coming, Evosport!
Old Apr 9, 2003 | 04:40 AM
Shine's Avatar
Thumbs up
After a test run, the C32 w/ODPS kicked asses,all of those 300+ ps performers !
996 C4 tiptronic stay the bottom, sorry 300 ps.
Chipped S4 330 ps
E46/M3 343 ps
S/Ced E36/M3 350 ps
CLK50K ? ignore it.
Old Apr 10, 2003 | 02:46 PM
CONGRATS, for how much? and how about a RS4 ot M5? Thanks!
Old Apr 10, 2003 | 08:17 PM
Shine's Avatar
Smile
We've a member with chipped RS4, 430 hp
C32 was overtook after 230 km/hr (C32 lead, rolling start at 100 km/hr)
That's before the ODPS.
In the range 100~230, RS4 still outperform enhanced C32 (even the 996 turbo), IMO
Afterwards, C32/ODPS can tail the RS4 all the way to Vmax
Meanwhile E46/M3 is getting far & far behind.(2,3....~8 car length)
That's odps boosts even higher at higher gears.
