Stupid things Ive learned about my car an embarrassingly long time after I bought it.
Old 02-23-2010, 04:45 PM
Forza1's Avatar
C32 AMG
Originally Posted by 02C32guy
Yeah, it's above the license plate. Under the Mercedes emblem.
Oh, I knew about that, I thought you meant a lever inside the car...
Old 02-24-2010, 12:15 AM
Forza1's Avatar
C32 AMG
ALSO, I can't believe I forgot this one, it's by far the most profound... It took me a year to realize that I had a cassette player in my radio hidden behind the screen...
Old 02-24-2010, 12:19 AM
jturkel's Avatar
02 C32 AMG
haha. that one took me about a yr to figure out as well.
Old 02-24-2010, 12:25 AM
firstshadow's Avatar
03 C32 AMG
Alright... you lost me
A cassette player... behind the screen? How does one access said cassette player?
Old 02-24-2010, 12:28 AM
jturkel's Avatar
02 C32 AMG
do you have command? i dont...not sure if it is different with command....but without command, there is a button that says "EJ" on it....stands for eject.
i've seen MBs with command have a tape player behind command when also pushing an "EJ" button....so look for one if that is your case
Old 02-24-2010, 12:35 AM
03 C32 AMG
Just investigated. I do have command, but no casette player for me. Ah well, not like I have any cassettes to play anyways
Old 02-24-2010, 12:54 AM
  #32
Quicktwinturbo's Avatar
CLS, SLK, ETC
Our stereo is or was speed sensitive...
Close/open window with remote doesn't work really well...
Old 02-24-2010, 12:59 AM
  #33
03 C32 AMG
I've known about the throttle reset, but haven't used it in months as I had forgotten about it. Went on a spirited drive today and decided to reset the throttle on a whim.
Oh my gosh... what have I been missing?! Throttle reset is my new best friend now!
Old 02-24-2010, 03:27 AM
  #34
RLx02's Avatar
C55
Originally Posted by Biscuit
I'm right there with you, heh. From my other thread:
- "One-Touch" start (bump the key forward and the car starts itself)
- Sunglass holder in glovebox...although I can't actually fit sunglasses in mine.
Oh man, how did you guys not know about the one touch start...that was one of nicest things about going to an MB lol.
Old 02-24-2010, 03:30 AM
  #35
CLS, SLK, ETC
I may not understood this correctly but one touch start means when u turn the key once to start the car while other cars have to hold it till it start?.. correct?
Old 02-24-2010, 04:16 AM
  #36
RLx02's Avatar
C55
yessir.
Actually I'm having a problem with the windows rolling up or down with the key. i used to use it a lot in the summer but i tried recently to roll it up and it wouldn't roll up or down with the key fob...
Old 02-24-2010, 07:11 AM
  #37
pullejo's Avatar
'12 E63, E55(sold), C32 (sold), '65 Skylark GS 445 convertible, '12 ML350
Closing and opening the windows from outside requires aiming the IR on the key fob at the receiver on the door handle. Once you realize that...it actually works pretty well.
Old 02-24-2010, 07:41 AM
  #38
RLx02's Avatar
C55
This i know; hence my statement saying that it worked fine for me in the summer. Recently it just hasn't been wanting to work even if point the key directly at the receiver on the handle.
Old 02-24-2010, 11:12 AM
  #39
02C32guy's Avatar
2005 E55
Yeah, I've read a lot of people saying the same things. That function on our cars is very finicky. Mine used to do it when it felt like it, but now I can get it to do it regularly as long as I put the key literally on the sensor.
Old 02-24-2010, 12:29 PM
  #40
Biscuit's Avatar
'03 C32, '08 ML63
I was trying to get this to work last night (never actually done it on my car before). But the sensor you're talking about is on the door handle near the key hole? A little square piece? And I should be able to just hold down the unlock button to make the windows go down if the key is aimed there?
Old 02-24-2010, 12:51 PM
  #41
02C32guy's Avatar
2005 E55
In theory, yes.
Old 02-24-2010, 08:40 PM
  #42
MBworld Guru
FrankW's Avatar
white and whiter
Originally Posted by JonMBZ
The recirculate thing is if you hold the button down it closes all the windows. don't feel bad I never knew you could bump the key either.
don't forget if you press and hold the same button again it'll return the windows to all the previous open position again.
Old 02-24-2010, 08:41 PM
  #43
MBworld Guru
FrankW's Avatar
white and whiter
that usually means your IR receiver is cooked.
mine only works on the passenger side and not the drivers.
Old 02-24-2010, 09:17 PM
  #44
Mark.D's Avatar
2005 C55 AMG
Could it mean your battery is low on your key fob (since pressing, and holding, subsequently uses more battery power)??
Old 02-24-2010, 09:23 PM
  #45
c32used's Avatar
LET C32 2002
+1
Old 02-25-2010, 03:24 AM
  #46
CLS, SLK, ETC
Yep.. IR receiver suxs... C55 only has one by driverside and mine doesn't work too well either... Sometime it does and sometime it doesn't..
Don't try it on your date.. Kinda ruins it... lol
BTW, how much is one of IR sensor?? I jst may change mine since summah is coming.. lol... But then u still have to be very close to the sensor as well..
Old 02-25-2010, 03:56 AM
  #47
MBworld Guru
FrankW's Avatar
white and whiter
check out rmeuropean.com they might have it. otherwise i dunno how much they are. never tried to replace it since I don't even use it. lol
Old 02-25-2010, 08:39 AM
  #48
masterianvii's Avatar
LADA 1600
There's a tire air compressor in the trunk as part of the spare tire toolkit. Never knew I had one!
Old 02-25-2010, 10:06 AM
  #49
02C32guy's Avatar
2005 E55
Yeah, it works pretty well too. Of course, I used mine once and now the fitting is loose and air escapes so it won't inflate a tire.
Old 02-25-2010, 01:41 PM
  #50
LADA 1600
... on the tire or the actual inflator?
Quick Reply: Stupid things Ive learned about my car an embarrassingly long time after I bought it.
