3M DI-NOC CF Vinyl
Old Mar 3, 2010 | 03:51 PM
GuidosGottaBenz's Avatar
05 C-230 Kompressor
Originally Posted by RLx02
Yeah, I never really liked blacked out grills but yours looked pretty good especially since your car is lowered too. I might redo it later because you can see tiny parts of chrome up close but for now its ok.
Paint it black first, then apply the CF
Old Mar 4, 2010 | 02:09 AM
RLx02's Avatar
C55
Originally Posted by s4avt
Thanks, but mine looks pretty ****ty, I ordered the film, just waiting to get in here : )
Are you good with vinyl? I suck tight corners and things like that. I'll buy beer if you wanna drive down to renton to help me lol.
I was thinking about that first, but the main reason why I'm doing the vinyl is so I can peel it off if I ever wanna sell my car and go back to stock.
Old Mar 4, 2010 | 02:29 AM
icecream's Avatar
W211 E55 - W209 CLK (gone)
^I also want to do vinyl on my roof.. do you know any reputable shop with cheap price in the seattle area?
Old Mar 4, 2010 | 01:22 PM
s4avt's Avatar
'03 CLK 55
so, I got the film, and I bought super sharp knife, well.. this film doesn't work like clear bra. I was pretty familiar with clear bra, but not this. I gotta keep working.
Haven't used heat gun yet, but will see how it turns out...
Old Mar 4, 2010 | 01:35 PM
BigBodyBenzC240's Avatar
...a panty dropper...
Are you using an exacto knife or just a really sharp knife?
Old Mar 4, 2010 | 02:08 PM
rockjock's Avatar
I DON'T COME HERE ANYMORE
If you're applying this there are a few things that I think most of you know-but some may not-
clean the surface well.
Clean it again.
Clean the area you're applying too.
Use an exacto knife-they'er cheap-so are the blades-dont streach the fabric when you dont have too-and keep your finger tips.
always lay out what you want to do-dont try to install while the part is attached to the car-you're asking for crap results.
Dont forget to clean.
Old Mar 4, 2010 | 06:54 PM
  #32
spr's Avatar
spr
And use a heat gun and a plastic bondo applicator! Without heat the material doesn't like to stretch. I wouldn't even attempt same without.
Old Mar 4, 2010 | 07:15 PM
  #33
s4avt's Avatar
'03 CLK 55
Exacto knife, I bought it with 10 extra knives so I can keep changing it to have more consistent cut... picked up at officedepot for 9 bucks...
Old Mar 4, 2010 | 07:16 PM
  #34
s4avt's Avatar
'03 CLK 55
Clean it again.
Good point... don't clean with just a water... use either hot soapy water or alcohol...
Old Mar 4, 2010 | 07:45 PM
  #35
dumpsta's Avatar
SLK280(Gone), C63, CLK550
After ordering and working a bit with some of this stuff and reading from other forums, do not stretch the film too much with heat. Stretch only as little as you need because if you stretch it out a lot it will come undone/bubble when heat hits it again (i.e. engine cover application/areas exposed to sun).
Old Mar 5, 2010 | 02:40 PM
  #36
Phil_W's Avatar
C32 AMG
Phil W..... How long did it take you to do this to your front intake cover? Also it was all done with one piece of vinyl correct? I think I am going to order some and attempt this but also spray 3 coats of clear over the vinyl and see how it stands up to the heat. Any inputs?
Hi, its best if you are two persons. I need 4 hours.
i wouldnt use clear coat, did it before and it looks bad.
