I changed my tranny fluid today
Old 06-07-2010, 06:32 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
it under the passenger side air box. You need to take it off the airbox to be able to access it.
Old 06-08-2010, 02:21 AM
mikekuriger's Avatar
2010 C63
It also has a tamper proof cap on it. if you break it off, you'll probably need to get a new one from the dealer to seal it back up.
Old 06-08-2010, 05:01 AM
hsbertiii's Avatar
c32 amg
I have a 2003 c32 amg. My owners manual gives a list of acceptable transmission fluids. Someone told me we have a zf transmission and we can only use mercedes fluid. Is this true or are there other acceptable fluids and what specifically are they? Thanks.
Old 06-08-2010, 05:22 AM
TemjinX2's Avatar
we do not have zf transmissions, your thinking early e46's. THe c32 transmission is produced in house by mercedes. Its preferable that you use oem, but others have used aftermarket without any real problems.
Old 06-08-2010, 11:01 AM
lkfoster's Avatar
'19 AMG E53 Cpe, '23 EQS 580 SUV, '88 560SL, '35 Ford 5w coupe, '53 MGTD and others
Originally Posted by mikekuriger
well, there are 3 quarts of fluid in the pan and 4+ in the converter. but usually you need an extra 2 or 3 quarts to pour in as the fluid comes out of the line. then again, I don't know for sure.
I changed mine last week. I got something like 3.25 liters with the drain plug removed and another 0.75 liters when I removed the pan.
I used Fuchs 4134 oil which is approved for the 722.9 transmissions and is backwards compatible with our 722.6. Not wanting to mess around with cooler lines I drained and refilled it twice to get more of the old oil out. Shifts are a lot smoother.
Old 06-09-2010, 06:22 AM
hsbertiii's Avatar
c32 amg
Has anybody used the castrol import multi vehicle fluid?
Old 06-09-2010, 07:03 AM
  #32
91RS's Avatar
2016 Chevrolet SS, 2006 Cadillac STS-V
I highly suggest just using the right fluid. I mean really, how often do you change the transmission fluid?
Old 06-09-2010, 11:57 AM
  #33
2010 C63
Not often enough I'm sure!
Old 06-09-2010, 06:00 PM
  #34
91RS's Avatar
Most likely, I just serviced my trans at 36k miles! I still have some fluid left over so I may do a drain and fill next time I change the oil. Sent the fluid off to be analyzed so we'll see how she looks.
Old 06-09-2010, 06:39 PM
  #35
2010 C63
I did mine at 100k.
Old 06-10-2010, 03:23 PM
  #36
moayes's Avatar
ML350 2010 AWD
If anybody is interested in getting a quote for the service you are looking for, check this out: http://repairpal.com/
This website gives you a rough estimate of how much the service you are looking for, will cost, both at the dealer or at a mechanic.
Old 01-02-2011, 05:01 PM
  #37
barciktiga's Avatar
2002 C32 AMG
what if you drained the oil first?
is there a way to estimate how much transmission fluid to replace instead of buying a dipstick?
Old 01-03-2011, 06:17 PM
  #38
gt4awd's Avatar
2005 Pontiac GTO 6.0 LS2 - Blue
Measure the amount of oil you remove... What if it isn't at the correct level to begin with? You can get the dipstick online for less than $50 dollars.
Old 01-03-2011, 06:30 PM
  #39
c32kompressor's Avatar
CLK55 AMG
Does anyone have a DIY instruction guide or anything on how to do this, I want to change mine very soon
Old 01-03-2011, 09:42 PM
  #40
gt4awd's Avatar
I like how the flush was done on this thread. A lot easier than getting under the vehicle. I took the other route and pulled the cooler line off the torque converter... The start of this thread is a DIY write up? What else are you wondering?
Old 01-11-2011, 09:34 PM
  #41
CLK55 AMG
Originally Posted by lkfoster
I changed mine last week. I got something like 3.25 liters with the DRAIN PLUG removed and another 0.75 liters when I removed the pan.
where is the drain plug located? mercedes told me you needed a certain key tool to do the tranny flush?
Old 01-11-2011, 09:42 PM
  #42
CLK55 AMG
also i didnt see where to pour in the new oil. can someone enlighten me, i must be lost here
Quick Reply: I changed my tranny fluid today
