intermittent power cut off situation - root cause?
Old Mar 31, 2010 | 03:39 PM
C32Berg's Avatar
GLK 320CDI - 2009 / SL500 - 2003
I turn to the C32 community with a problem that I have experienced recently when driving my C32. Ocasionally I feel that the power is cut off for a second, not more. It happens at speeds at 60 mph or above and can be under acceleration OR at crusing with or w/o the cruise control engaged. I can drive for miles w/o feeling anything and then suddenly this power cut appears. No alarms are triggered or faults are detected on the screen.
Before taking the car to the MB shop I thought I turn to you guys to see what you have to say. My own thoughts are:
- some fuel delivery problem
- MAF HW problem
- some engine mgm problem (I run Kleemann stage 1 HW & SW)
Your comments and thoughts are greatly appreciated
Drive safely and enjoy the Eastern holliday / Goran
Old Mar 31, 2010 | 03:45 PM
Dingleberry's Avatar
Marsaydees
intercooler pump
Old Mar 31, 2010 | 04:12 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
yup check that first.
Old Mar 31, 2010 | 09:25 PM
loudandheard's Avatar
C32/C55 AMG
Definitely check the pump or more like replace it.
Old Mar 31, 2010 | 10:36 PM
evilsaint's Avatar
'02 C32, '10 135i M-Sport, '10 E63, '17 GLE63S
Get your car warmed up then run it semi-hard for at least ten minutes. Stop somewhere suddenly and shut it off with the right-front window open (optional). If you can't hear a pump turn on and run for a few seconds, then your IC pump is definitely going. It's obviously not exact science, but it's a decent test
Old Mar 31, 2010 | 11:47 PM
C32/C55 AMG
Mine would still turn on, but some thing was either clogged or the pump was working at its best.
Once I replaced it, my gas mileage decreased. I'm not saying that will happen, but let just say my car had a lot more power on tap more often.
Old Apr 1, 2010 | 03:01 PM
C32Berg's Avatar
Originally Posted by Dingleberry
intercooler pump
Thanks for your input. Still, I thought the IC pump was somewhat 'digital' either it works OR not not. I can drive for long w/o any problem and then I have this strage experience where the power is off for a fraction of a second and then back again within a blink. The probel also apperas in somewhat the other direction i.e. I cruise at a fixed speed at let say 60-70 mph and then without moving teh accelerator the car gest an extra acceleration for a second. It's weird and har to explain....Still, I take your advice and will check my IC pump. Pls recommend the best way to detect if it is OK or not.
Old Apr 1, 2010 | 04:34 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
You should either buy a code reader and see if you have any pending codes stored. Could be something to do with your Throttle Actuator or pedal assembly. Sometimes some of these errors don't trigger a CEL, but store "pending" codes that can be read to help troubleshoot.
Good Luck!
Old Apr 3, 2010 | 11:45 AM
C32Berg's Avatar
...I will let the MB shop have a look on Thursday and see if they can find out what's wrong. I keep you posted....
Old Apr 3, 2010 | 11:53 AM
gt4awd's Avatar
2005 Pontiac GTO 6.0 LS2 - Blue
The pump is an intermittent problem. When it starts to go it will work almost all the time with occasional cut out. The symptoms will continue to get worse. When the pump on mine was shot highway speeds effectively cut out the most. There's the difference between an electrical component of the pump failing, and the electrical brushes wearing out due to normal wear. How many miles does you C32 have?
Old Apr 4, 2010 | 01:58 AM
ali saklaoui's Avatar
C32AMG.335 e92 fbo.protomotive996 gt2
This is the IC pump or the charge air temperature sensor faulty(internal short cicuit)
Old Apr 5, 2010 | 06:04 AM
C32Berg's Avatar
Thanks for the comments and update. I have got approx. 160K miles on it today and does not know if the IC pump has been replaced by previous owner.
Old Apr 6, 2010 | 12:30 AM
gt4awd's Avatar
How many miles when purchased? I would definitely start with replacement of the pump. Get either Johnson CM30, or Ford Lightning pump. Johnson flows a little more, and appears to be more reliable. Lightning is the same exact pump as OE at 1/3rd the cost. Only difference is the electrical connection, and the pump head. You can pull the head off your old pump, and use it on the Lightning. Directly bolts up. If you want to tackle the pump yourself I wrote up a DIY thread on benzworld.
http://www.benzworld.org/forums/w203...placement.html
Old Apr 6, 2010 | 12:44 AM
Marsaydees
Old Apr 7, 2010 | 07:13 PM
C32Berg's Avatar
...just kidding correct conversion from metric shall be 60K miles...
Old Apr 7, 2010 | 07:17 PM
C32Berg's Avatar
Is the CM30 an direct replacement or what does it take to make it work in an C32? Asking because the Johnson pump is Swedish made and easy to source for me in Sweden.
Old Apr 8, 2010 | 12:05 AM
gt4awd's Avatar
I believe you can move the rubber coupler piece onto the CM30, and the original bracket setup can be used.
Old Apr 16, 2010 | 03:21 PM
C32Berg's Avatar
...you where right (as always). The intercooler pump needs to be replaced....I will go for a CM30. Swedish made and easily available for the price equal to USD75 from a local rep.
Thanks for all good input & advice
Old Apr 16, 2010 | 03:26 PM
C32Berg's Avatar
USD75 was too good to be true.
It is actually 175 USD for the Johnson pump here in Sweden. You guys get a good deal over there....
Old Apr 16, 2010 | 04:24 PM
c32used's Avatar
LET C32 2002
Exclamation
intercooler pump
+2 if for some reason its not this check the fuse that may be your problem..I had same issue and automatically replaced pump but issue still exist then troubleshooter uncovered that when needed the I/C pump didn't turn on so checked fuse and all good again.
Old Apr 17, 2010 | 02:47 PM
merc4ever's Avatar
c32 amg
- MAF HW problem
det kunde du ta på det svenska forumet så kunde jag hjälpa dig direkt
Old Apr 17, 2010 | 06:56 PM
C32Berg's Avatar
I will do that, thanks for the advice
Old Apr 17, 2010 | 06:57 PM
C32Berg's Avatar
...just trying to broaden my MB network..
Old Apr 17, 2010 | 07:25 PM
60n5pt1's Avatar
2002 C32 1987 190E 2.3 334K miles and going
REPLACE the IC PUMP! just do it
Classic symptom.
Old Apr 18, 2010 | 07:07 PM
W203Ramos's Avatar
'03C32 Obsidian Black, '76Toyota Celica GT TRD, '12R350 4matic Arctic White, '06 ML 350 arctic white
@c32berg...very simple job about 45 min with a six pack of beer
