C32 AMG coolent loss
AQUIRED A C63 AMG PPP
Hi i have owned my c32 for 3yrs it has every xtra and i absalutly love it...but ive had a nightmare with it , pumps went a/c cond went alternator, amg batery cable, re-erscreen, all 4 discs, etc , recently the headgaskets went so ive just had it back after weeks and now it still loses coolent and theres no sighn anywhere of it ive had a smoke test just in case the gaskets went again ...........HELP its killing me !!!know one knows whats goin on...and had the gearbox tested for coolent....can anyone help
well thankyou i will tell the mechanic your suggestions i hope your right and it aint a cylinder head prob im desperate to solve this its been since january
03 g35 coupe...........02 c32 Sold
I really doubt its the head. The engine itself is built very well from AMG. Its usually the accessory components that go bad like the radiator, intercooler pump and intercooler. I would start by replacing the intercooler first.
If you take off the intake and take off the manifolds. You can check for the green grunk, but also if you take a flash light and feel around the area under the intercooler you should see of feel some liquid in the valley where there intercooler is located.
http://www.parts.com/oemcatalog/inde...layCatalogid=0
Your only real option now is to get an OEM one from the dealer or a parts website. Code 3 AKA HP Autowerks no longer offers theirs and even if you could find a used code 3, there were a lot of fitment issues. Eurocharged doesn't make an intercooler. I think you may be confusing it with a heat exchanger. The intercooler sits under the supercharger and cools the supercharger. The heat exchanger acts like a radiator to cool the liquid coming from / going to the intercooler. PITA is an acronym for "Pain In The ***". This is what you need:
2003 porsche 996 turbo
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
![Wink](https://mbworld.org/forums/images/icons/icon12.gif)
mb uk have quoted me £75o+vat oooowwww!! so like u say if i ring crysler for the same part it could be cheaper...good thinking
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
For C32 and SLK32, the part number is the same. It is A1125000000 for $822.
![](http://www.parts.com/schematics/5/5775206.gif)
What you get for $300 is most likely the HE.
![Cool](https://mbworld.org/forums/images/icons/icon6.gif)
WOULD THE INTERCOOLER LEAK CAUSE OIL TO GET IN THE COOLENT BOTTLE???
well not now ! i had the headgaskets done because of the oil in coolent etc...but since i had it back it just loses coolent so i just thought maybe it was the intercooler all along but as you say this could not really happen, i guess the gaskets went and the intercooler...
Well i ve just come back from the mechanics and weve had the supercharger of and theres no sighn of a leak .....which has left us exasparated for an anwser anyone got any more ideas ???
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
I have had the gaskets done and ptested .................im lost here do you think its the bottom end of the engine..? but theres no sighns of this
1 Post
'03 C32, '08 ML63
Anyways, you would definitely lose coolant with glycol contamination problem. But I think if he was losing enough that he was having to refill his transmission would be shedding tears by now.
Maybe it's a simple external radiator leak though? I'm guessing you don't get any puddles or anything obvious?
And how did they confirm it wasn't the intercooler? Did they pull it out and do a pressure check on it?
