vibration from the rear
Old Apr 4, 2010 | 08:26 PM
W203Ramos's Avatar
'03C32 Obsidian Black, '76Toyota Celica GT TRD, '12R350 4matic Arctic White, '06 ML 350 arctic white
Anyway, was driving on the expwy yesterday and the car started to vibrate from the rear out of nowhere. I pulled over and saw nothing I thought i might have ran over something. So today the same thing happened and when I pulled over ....NADA but i was suspecting that the rear right caliper might be sticking every now and then so as soon as I got home I bled all four corners. Will see what if it happens again. Has anyone had this hapen to them? Any suggestions would be greatly appreciated. Thanks in advance
John
Old Apr 4, 2010 | 08:30 PM
Dingleberry's Avatar
Marsaydees
perhaps a wheel weight fell off
Old Apr 4, 2010 | 08:35 PM
W203Ramos's Avatar
I was hoping thats all it was but it comes and goes. it would vibrate @65mph and below until i stop and shut the car off and after a quick inspection finding nothing, I start the car up and go and no vibration...weird huh?
Old Apr 5, 2010 | 09:28 AM
W203Ramos's Avatar
same thing happened this am. has anyone had their rear calipers stick? if so what are the symptoms?
TIA,
John
Old Apr 5, 2010 | 09:49 AM
02C32guy's Avatar
2005 E55
Check the front splash guards in the wheel wells. Sometimes these come loose on mine and rub against the wheels. At highway speeds it feels like a vibration coming from the back even though it's the front splash guards rubbing. This has happened to me a few times and as soon as I bolt them down it goes away. Last time it happened I was on the turnpike and had to use the fishing pliers out of my vest that happened to be in the trunk. The time before I had a knife and had to cut away the whole piece. Moral of the story, make sure you put them back on correctly and check the screws once in a while.
Old Apr 5, 2010 | 11:54 AM
mikekuriger's Avatar
2010 C63
you could also have a bad tire. any number of strange harmonics can be introduced, or come and go when a tire is bad.
Old Apr 7, 2010 | 04:46 PM
W203Ramos's Avatar
changed all pads(akebono) and bled brakes on all four cornes. no symptoms since. btw upon bleeding the brakes, the first squirts of fluid was darker than usual....so far so good Thanks for your suggestions
John
Old Apr 7, 2010 | 06:57 PM
nelson09's Avatar
1999 E320
Same thing happened to me a while back (any time I'd reach 45-50 mph) It ended up being a loose wheel. The wheel wasn't square when we bolted them back on so I'd suggest jacking your car up, completely removing both rear wheels and make sure they are mounted square/flat and bolt them back on. Good Luck.
