5.4 AMG engine differences and supercharging
hello,
I actually own a SLK55, but I have found that there was a C55 in existence that had been supercharged. I tried looking for the build thread, but could not find it. I’m looking into doing this to my SLK55, and would prefer to go the OEM route rather than Klemann or Rentech. I have looked up the specs on the engines but could not find the detailed differences between the N/A and the supercharged ones.
Here's what I've found
SLK55 | C55 | SL55
360hp | 367HP | 476HP
376TQ | 376TQ | 516TQ
11:1 comp | 11:1 comp | 9:1 comp
97mm bore | 97mm bore | 97mm bore
92mm stroke | 92mm stroke | 92mm stroke
so, are the internals actually different in the N/A motors or did they just use thicker head gaskets to drop the comp ratio?
my guess is that they used different pistons, since the bore and stroke are the same. I remember reading that AMG builds their engines to run at about 60% of their potential, is that true?
If so, would anything need to be modified internally in order to supercharge the N/A motor?
I found a used supercharger from an SL55 on Ebay. it looks like it replaces the whole intake assembly as well. would the crank pulley off a SL55 work on the N/A motor for the drive belt on the S/C? also, would i need custom tuning for the s/c or is there a map readily available? does the fuel pump from the SL work on the C/SLK class? what about injectors/fuel rails/FPR's? Please point me in the right direction in my research.
thanks
SLK55 | C55 | SL55
thanks
hello,
SLK55 | C55 | SL55
thanks
SLK55 | C55 | SL55
thanks
Several others on here also have Kleemann superchargers on their C55s, but I believe they purchased it that way.
IIRC, for the transplant to fit, didn't they have to somehow elongate the front end b/c the M113k motor and tranny wouldn't clear the W203 engine bay as is? My comment about it "might" mattering is that the C55 has a different front end, as it is part W209 (IIRC). so perhaps the M113k motor and tranny would clear and the front end would not need to be elongated.
if this is NOT the car that i've read about, then completely ignore that post lol.
You can go OEM/AMG but you spent lots of $$$ than kleemann, the kompressor kit by kleemann round 9k$ - 9.5k$, the custom AMG round 15K
Best option: buy a used 55K engine & put them on![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Fabio Daniel
Fabio Daniel
+1, the S7 and S8 are prime examples of Kleemanized C55s, Most were purchased that way.........
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
My friend put a complete 55k motor in his C43.
Hooleyboy would be the best person to ask about just putting a charger on.
The NA55 motor has higher compression pistons than the 55k motor.
If you do decide to go the AMG charger route I may have a supercharger for sale. Pm me if interested
hello,
. . . . . . . so, are the internals actually different in the N/A motors or did they just use thicker head gaskets to drop the comp ratio?
thanks
thanks
Just glancing at the part numbers, internally, the supercharged engine has different rods, rod bearings, pistons, heads, cams, valve springs (the 55K uses dual springs), and crank. This is a very short list of some internal differences. There are other external issues. The ECU controlled SC clutch is a good example.
An aftermarket SC may be a viable option.
2002, 54, 55, amg, c55, engine, engines, mercedes, motor, na, project, supercharge, supercharged, supercharger, supercharging
