Sunroof leaking but not the actual sunroof.....
Old May 18, 2010 | 02:50 PM
trbo2nr's Avatar
2004 C32, 2006 Honda CBR1000RR, 2007 Harley NightRod, 2013 Harley Road Glide Custom
I have water coming in from the passenger grab handle near the sunroof. Ever see that happen?
Old May 18, 2010 | 11:35 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
Yes, you could have a leak in one of the seals on the roof of the car likely around the sunroof.
Old May 19, 2010 | 11:22 AM
BryanW203's Avatar
I have seen this once or twice, it only seems to happen if it is raining extremely hard and the car is parked in the perfect position so water pools up instead of draining through the sunroof drains, or the drains are clogged.
Old May 19, 2010 | 11:39 AM
slowsky's Avatar
2011 C63
I have this exact issue...but only going through car washes...
sat there with a hose running water continuously and it not leak...
downpours and hurricane like weather with no leaks...
Old May 19, 2010 | 11:57 AM
14cue's Avatar
05 C55
Same thing happened to me. One short visit to the dealer and the seal was replaced and problem fixed.
Old May 19, 2010 | 02:20 PM
trbo2nr's Avatar
How much did it set you back? I cleared the front drains and looking for the rear drains (must be hidden fairly well).
Old May 19, 2010 | 03:53 PM
14cue's Avatar
05 C55
^was free. covered under my extended warranty.
i dont imagine it would have cost much though. took less than 10 mins and parts were probably, dare i say it, cheap.
if you have a good relationship with your SA, i am sure they can hook you up for such a minor issue.
Old May 19, 2010 | 05:07 PM
trbo2nr's Avatar
Nice. I have a warranty too. Will check that out. Thanks.
Old Oct 14, 2011 | 05:56 PM
trbo2nr's Avatar
Looks like I will have this fixed. It poured the other day and water returned. Only happens when it pours and never under normal rain.
You remember how much it costs to replace the seal?
Old May 21, 2012 | 04:15 PM
trbo2nr's Avatar
I had the revised seal put in and was fine for months. Now coming home today, my kid goes....dad, water is coming in.....
Crap. So, I am googling this yet again.
Old May 22, 2012 | 12:26 PM
Wilsophia's Avatar
2002 W203 C32 AMG / 1997 Toyota Corolla AE110
https://mbworld.org/forums/c32-amg-c...e-cracked.html
I have the same problem of the sunroof leak under heavy rain, finally I found that it is no related to the sunroof seal.....l it was the sunroof drain pipe seriously corrosion (rusting) and made leak. I Need to grind all the rust on the pipe, and added some anti rust paint on it as temporary fix
You should check
1) open the sunroof and put some water(several cups) at the sunroof side track. Water will drain through the drain pipe. If u have problem to the pipe. Water will drop ontop from the headliner, then....
2) need to partially remove the headliner and check for the roof drain condition.
I think this is a common problem to w203 model.
I will st more photo tomorrow.
Old May 22, 2012 | 02:27 PM
trbo2nr's Avatar
You should check
Thanks for the info.
