Ideal launch sequence?
Old Jun 22, 2010 | 01:46 AM
ohfiveC55's Avatar
2005 C55 'Silver Bullet'
Hold the brake and give it throttle until 3k, 5k rpm?
Just lay the hammer down?
Buttons on/off?
What's the word on the best launch sequence?
Old Jun 22, 2010 | 01:49 AM
JonMBZ's Avatar
06 C55, 09 E350
Not sure, but I know hooley use to launch his car in dyno mode so the ESP doesn't interfere.
Old Jun 22, 2010 | 02:57 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
i think on the c32 its dyno mod..hold brake 1.5k rpm then launch. From what i heard it was the best way of reduce tire spin.
Old Jun 22, 2010 | 10:36 AM
OverDrive's Avatar
Volvo
Word! best way to do it on or off the track!
Old Jun 22, 2010 | 11:06 AM
thegreatfnr's Avatar
05 C55 AMG
On street tires I was able to pull a 2.0 60ft, with more practice Im sure I could pull a sub 2sec 60ft. I did so by putting the car in Sport Mode, ESP off, place the car into 1st gear. Then do as TemjinX2 said by holding the brake and bring the RPMs to about 1.5K. At go time, let off the brake, roll into the throttle and feather it as needed to reduce wheel spin.
Old Jun 22, 2010 | 02:01 PM
MIKESV8's Avatar
Aston Martin V8 Vantage
Buttons on/off?
that's what i do, go into manual mode, hold brake and build up to 3k rpm with traction control off. i have michelin ps2's on my car and they slip a little bit, but it's the perfect sequence. i tried doind it with my old pirelli p zero's and they were up in smoke.
Old Jun 22, 2010 | 05:16 PM
SETSEROCK's Avatar
HPF E46 M3 Turbo, LET C32 AMG
The C55 has a Sport button?
Old Jun 22, 2010 | 06:36 PM
MIKESV8's Avatar
yea...omg you have an hpf m3? is it red by any chance? my friend may have got a ride with you at bimmerfest if you went a month ago.
Old Jun 22, 2010 | 10:36 PM
SoCalC55's Avatar
2019 AMG C43
Yep!
Sport
Shift to 1st
Rev to ~1500
Dont mash the pedal, but feather it until your at the top of 1st
Let the car shift itself
Old Jun 23, 2010 | 12:49 AM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
It’s not so much a 'sequence' as it is utilizing proper throttle technique.
Find a deserted stretch on which to experiment, and then head to a local 'strip to verify your newfound proficiency.
1.9x 60' times are easily achieved with this chassis, even on a stocker. To do so only requires practice and decent tires.
Old Jun 23, 2010 | 02:35 AM
MIKESV8's Avatar
that is defiantely the best way of doing it. apparently the e46 m3 smg has a launch sequence? does anyone know how affective they are?
Old Jun 25, 2010 | 11:59 PM
Quicktwinturbo's Avatar
CLS, SLK, ETC
Launching is very tricky... I do not launch my car hard from standing but I did practice after I got beat by a newer slk350 back in the dayz.
1. Sport
2. brake rev 1.5-2k
3. 40-60% Throttle (Check n see if u have enough grip to go then WOT) Also depends on ur tire cond
4. WOT
5. Hit nawzzzzzzzzzzzzz when someone is faster than u.... lol
4.
Old Jun 28, 2010 | 12:13 AM
kindafast's Avatar
W210 E55 & W204 C63
What I used to do at the track is the following:
-Reduce rear tire pressure by 7psi
-If you have street tires heat them up by spinning until first smoke
-ESP off
-hold the brake in and keep the RPM's at about 1700
-feather the throttle and keep it pinned until you cross the line.
Old Jun 28, 2010 | 05:54 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
put 3 more people in the car with you and just mash the throttle and go. no wheel spins.
lol...but seriously, don't bother putting it in dyno mode unless you have a quaife LSD because in 99% cases you'll just spin one wheel.
