Need new front lights!!Help!!
Old Jul 2, 2010 | 08:15 AM
H13BS M's Avatar
2002 Mercedes Benz C32 AMG
Hi peeps
I live in the uk, and i own a 2002 c32 AMG
I still have the stock xenon frosted headlights which look awful. How do I do a clear headlight conversion like evry single one of you do on here. I just want clear headlights to make it look modern, but still have xenon. Could i just buy standard clear lenses, and take apart my old lights. Meaning i use all my original backings and just put the front clear part of the new lights onto them?This way they would be clear and still have xenon. Sorry its near to impossible to get clear xenon lights after market for my car in the uk!
Cheers Mike
Old Jul 2, 2010 | 09:59 AM
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
Explain what you mean by frosted? Are you reffering the the fluted lens or are your lens discolored due to age? If the latter then their are several good DIYs here on the forum that can show you how to polish them to like new condition. If the former it is there to direct the light beam and avoid scatter. More info required.
Old Jul 2, 2010 | 11:42 AM
H13BS M's Avatar
Hi there bud
What i'm trying to say is the front lights are frosted plastic lenses. As in they come from the factory not clear. Everyone in the states has clear plastic lenses, meaning you can see the backing of the lights, where's mine you cannot because on early models the plastic lenses to the light they came frosted as in there not clear. There not dirty, they come frosted.As in not clear, so they look old fashion.
Old Jul 2, 2010 | 01:54 PM
King320's Avatar
03 C32 AMG
Most people here switched for eBay Depo housings.
Old Jul 4, 2010 | 10:26 AM
H13BS M's Avatar
Sorry, what does that mean?
Old Jul 4, 2010 | 10:34 AM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
Depo is a brand that makes aftermarket headlights, they're cheaper than buying the OEM's
Old Jul 4, 2010 | 01:57 PM
saer1one's Avatar
2002 c32 AMG 2012 c250 Coupe
http://cgi.ebay.com/ebaymotors/STOCK...ht_10818wt_941
This is what your looking for..
Old Jul 4, 2010 | 03:00 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
You can't just replace the frosted lenses with clear ones as the frosted glass is what aims part of the light.
You will need to replace the whole headlight assembly, however aftermarket depo conversions will typically give you less light that your frosties.
BEst way is to upgrade to OEM true bi-xenons, but that will set you backk at least $1000.
or, get these:
https://mbworld.org/forums/mobile-electronics-lighting/356097-fs-w203-oem-bixenons-w-6000k-bulbs.html
There's plenty of threads about this in the regular W203 forum. Try searching there.
