Researched Springs and Still Need Help...
Old Jul 9, 2010 | 03:15 PM
chris.bachman's Avatar
a car.
I've committed to purchasing springs instead of coilovers because I'm just not ready to spend over $1,000 yet to lower my car. With that being said I'm just trying to decide which spring to get to achieve my desired end result.
First and foremost I want to close the gap up front. I'd like the rear height to remain close to it's current position as I don't want to tuck under the fender too much. I've read about the H&R springs, the Renntech springs and the Eibach springs and they all seem to drop it about 1", correct me if I'm wrong.
I see everyone talking about #4 spring pads in the rear to help achieve the effect mentioned above. Problem is I have no clue what a spring pad is; Do they come with the springs? Is is something I have to order from MB? What is it?
So, that's the matter at hand, all help is greatly appreciated.
Old Jul 9, 2010 | 04:49 PM
pointman's Avatar
a car that can't do the throttle reset.
Vogtland's are also recommended.
Renntech's are a bit more expensive, but pics and reviews say they are awesome.
H&R has supposedly shown slight variations in how much they settle.
Never read anyone having Eibach's on their 32.
Spring pads can be had from the dealer.
Old Jul 9, 2010 | 05:25 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
^pointman is pretty much on point
the eibach supposely has more drop then H&R btw.
RENNtech springs is good because their spring rate is matched with SACHS struts/shocks which is the OEM company that makes the AMG struts/shocks on the C32/55.
Old Jul 9, 2010 | 06:50 PM
a car.
So RENNtech with #4 pads will be a direct fit without any adverse effects or the need to change other components of the suspension?
Old Jul 9, 2010 | 07:27 PM
AnimC32's Avatar
C32 AMG
What number are the stock pads in the front? What is the front pad number to lower the front even more?
Old Jul 9, 2010 | 07:51 PM
a car.
I've read there are no pads up front. That was another question I had.
Old Jul 10, 2010 | 12:06 PM
wawy's Avatar
2013 C63 AMG P31, 2014 GMC Sierra (6.2)
Vogtlands will lower your C32 more in the front and just a tad in the rear. You will not have too mess around with pads either!
Old Jul 10, 2010 | 12:25 PM
loudandheard's Avatar
C32/C55 AMG
I actually like the height in the rear of my car, but the front definitely needs lowering. I'm thinking of just using different springs in the front.
Old Jul 10, 2010 | 03:22 PM
320 dreamer's Avatar
2003 porsche 996 turbo
my slk32 has eibachs from the factory so its a safe bet the c32 springs are the same brand.
pads run in 4mm incrememnts from from #1 being the thinnest to #4 if the rear and #5 in the front.
Old Jul 10, 2010 | 03:34 PM
SGTzAMG's Avatar
Veteran: Army
02 C32 AMG, 05 SL55 AMG, 09 SL63 AMG, 14 E350, '18 G550, 92 300ZX & 15' GL63 AMG
interesting....i actually am interested to see how a C32 looks on vogtland springs.
i have H&Rs on mine. and i think the front is settled pretty good finally.
Old Jul 10, 2010 | 11:36 PM
AMG_Dom's Avatar
2005 C55 AMG
Does the need for the spring pad apply to the C55 as well?
I was thinking about getting H&R springs soon (not sure which ones though)
Old Jul 11, 2010 | 03:38 AM
AnimC32's Avatar
C32 AMG
C55 rims though
Old Jul 11, 2010 | 10:55 AM
C32/C55 AMG
Originally Posted by AnimC32
C55 rims though
Your car looks amazing and the drop looks good too. We're almost twins.
I need a drop bad:
Old Jul 11, 2010 | 12:10 PM
AnimC32's Avatar
C32 AMG
I need a drop bad:
/Picture342.jpg[/IMG]
Ha! I even had the same grill before I went for the '05 one!
Old Jul 11, 2010 | 12:35 PM
C32/C55 AMG
Nice
