Help with the final pieces of the engine rebuild
Old Aug 1, 2010 | 02:55 AM
chamm's Avatar
2002 c32 amg
I am down to the final steps to get the C32 back on the road, but ran into a few small problems. The first one being the vacuum lines to the purge valves and supercharger. Does anyone have a good picture of how they are routed or a routing diagram. I couldn't tell from the EPC how they go from the part at the front of the engine where there are two vacuum lines coming out.
The second being I have a small brown, grounding, wire that I can't remember where it came from. I believe that it was attached to an accessory of some kind, either the power steering pump, or AC compressor. Its about 6" in length and has eyes on both ends for a bolt to go through.
Any help is greatly appriciated, as always.
Old Aug 1, 2010 | 03:11 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
this should give you some ideas.
https://mbworld.org/forums/c32-amg-c...stall-diy.html
Old Aug 1, 2010 | 12:19 PM
loudandheard's Avatar
C32/C55 AMG
There should a ground cable connected to the power steering pump, looking over the pump from the front of the car, it would be on the bottom right hand side. There are 3 bolts total that are used on the back of the power steering pump, so see if that one is missing.
I'll be happy to take some pics, just let me know where.
Here are some pics that I have of my engine bay.
