Want a new engine?
Old 02-10-2011, 10:08 AM
WaveyKat's Avatar
Something Slow
Does Any one Know if the Headers From The C320 Can fit SLK32 Engine? i want to do an engine swap, but i have VRP Headers on my C320 and would like to re-use them..
thanks
Old 02-10-2011, 10:38 AM
320 dreamer's Avatar
2003 porsche 996 turbo
thanks
mike the exhaust manifolds are built for the make of the car. the engines would basically be the same(slk32 engine vs c320 engine) meaning both are the 3.2 v6. your headers should bolt up with no issues.
Old 02-10-2011, 12:56 PM
WaveyKat's Avatar
Something Slow
ok good good just wanted to make sure :-)
Old 02-14-2011, 03:49 AM
ML500K's Avatar
C32 '02
I'm assuming this includes the transmission/ECU and all? One thing you might want to check is the size of the rear diff. is it the same as a C240. The other day i say a c240 jacked up and the c32 diff is much much bigger than the c240 to handle the torque. GL with your transplant.
Old 02-14-2011, 04:52 PM
WaveyKat's Avatar
Something Slow
well i have C320.. and am not sure of the Diff size.. hopefully the SLK32 Diff can work on my C320
Quick Reply: Want a new engine?
