I need some spark timing info
"ECU will also retard timing if it sees knock" - only if the tune allows it to though, right? I've read some alleged reports in the last couple years that some tunes remove/limit some of the ECU's ability to successfully retard enough timing if it senses knock/detonation.
Altitude helps in this case...
