Jon's new brake kit
Old Apr 24, 2003 | 06:51 PM
Zeppelin's Avatar
C32
Ben,
If you can find a way that I can use my front brakes on the rear, I would take a set. I just can't bring myself to replace already good brakes with others unless they can be used in the rear.
Old Aug 5, 2004 | 02:43 AM
Pelle75's Avatar
MB SLK 230 kompressor -01, MB C32 AMG -02
Here is a RS6 owner comments about Brembos 8 piston kit
http://www.movit-scandinavia.com/en/...ts_audirs6.asp
Originally Posted by Mach430
The 8-piston monoblock caliper and rotor are heavier than the 14" 4-piston kit, but it makes up for it in massive brake torque. The kit is not currently being made, but our close relationship with gives us access to building the kit if there is enough demand. Anyone???
Here is a comparison picture of the 15" 8-piston kit vs the 14" 4-piston kit. Again, if there is enough demand, I will have it made!
Old Aug 5, 2004 | 02:44 AM
Pelle75's Avatar
Originally Posted by Jon Winter
That's funny, I called Evo Sport a couple of times and asked about big brake kits. The only 15" kit that I could get from them was the Kleeman kit.
Kleeman buys brakes from MOVIT
Old Aug 5, 2004 | 11:59 AM
smgC32's Avatar
I can't see any of the pics withing this thread??
Old Aug 5, 2004 | 12:30 PM
MgnFicnT's Avatar
'02 C32 AMG
i cant see the pics
Old Aug 5, 2004 | 11:54 PM
smgC32's Avatar
It is quite possible that the additional brake torque generated by the 8 piston design will negatively affect brake bias on the C32. I would have to see the specs. Ben, can you confirm the piston size for this caliper as well as the sweep area of the total pads combined? Unless a custom caliper is made for the C32, using the standard Porsche 8 piston caliper with Porsche sized pistons will overbrake the car if you are too hard on the brakes. In addition, the 380mm rotors are not only larger in diameter, they are thicker as well by a couple of mm, either 34 or 35 depending on manufacturer vs. 32 for the 355 kit, and 28 for the 332 or 328. If I remember correctly, the 380 disks weight more than 10lbs more than the others! They do look good on any car though! If our cars weighed more than 4000+ lbs, then an argument could be made as to their advantages, but in terms of brake performance on the street, the stock set up is just as good and will stop in just the same distances as any BBK with the identical pads and tires.
