O2 (Oxygen) Sensor Replacement
Old Aug 28, 2010 | 12:15 PM
loudandheard's Avatar
C32/C55 AMG
My check engine light has been coming on sporadically and I always get the same codes, P0432 and P4022. I had a friend check my O2 sensor and the sensors before the catalytic converters are a bit slow, but working with in spec, the sensors after are working erratically and are probably causing my code. My cats seem to be good and I have not had any rough idle or misfires.
So I'm going to replace my O2 sensors after the cats. Here's a thread of the O2 sensors that I found: https://mbworld.org/forums/c32-amg-c...o2-sensor.html
Apparently the O2 sensor are as follows
Right, before cat - 001 540 50 17 Bosch part # BSH081900
Cheapest price I found $119.17
Left, before cat - 001 540 07 17 Bosch part #BSH081901
Cheapest price I found $135.79
Right/left, after cat - 001 540 46 17 Bosch part #BSH081902
Cheapest price I found $140.19 -I need to buy two of these and they would be the most expensive.
Here is the website I found these prices at even parts.com could not beat these prices: http://www.alloxygensensors.com/Shop...32+AMG&mode=PA
Does anyone know of any where cheaper? When I need to replace the O2 sensors before the cats, is there a wide band O2 sensor that I could replace those with?
Old Aug 28, 2010 | 10:41 PM
rdw's Avatar
rdw
c32
check out amazon
Hi
Check out amazon.com
part # Bosch 16167
part # Bosch 16183
part # Bosch 16179
I'm having the same problem with the check engine light. Just purchased today.
Hope that helps
Old Aug 28, 2010 | 10:58 PM
buffyclk500's Avatar
clk500
I got 2 if u ned they r used
If u want them
Old Aug 29, 2010 | 12:06 AM
C32/C55 AMG
Originally Posted by rdw
Hi
part # Bosch 16167
part # Bosch 16183
part # Bosch 16179
Hope that helps
So does that mean that I can use what ever O2 sensor I want, they are not C32 specific?
If u want them
How many miles and are they for the C32?
Old Aug 29, 2010 | 12:59 AM
clk500
they r from a clk500 and around 80000 miles on them and they worked when i took them off
Old Aug 29, 2010 | 11:56 AM
rdw's Avatar
rdw
c32
Opps!!
Opps!! sorry about that. from the website
Bosch 16183 Oxygen Sensor, OE Type Fitment
This product fits your 2002 Mercedes-Benz C32 AMG
• Notes: OE TYPE AFTER CATALYST
I
Bosch 16179 Oxygen Sensor OE Type Fitment
• Notes: OE TYPE BEFORE CATALYST - LEFT SIDE
Bosch 16167 Oxygen Sensor, OE Type Fitment
• Notes: OE TYPE BEFORE CATALYST - RIGHT SIDE
Old Aug 29, 2010 | 12:28 PM
C32/C55 AMG
I
That's awesome, is there a way that I can verify that information? I do not mean to doubt you, it's just I have different bosch part numbers that I believe to be oe part numbers.
Old Aug 29, 2010 | 12:41 PM
C32/C55 AMG
I found the information on the Bosch website. I never even thought of looking there, I wonder why I have different part numbers and why they are so much more expensive. Thanks for saving me a bundle, I can almost replace all of them for the price that I was going to buy two.
http://www.boschautoparts.com/Vehicl...=OxygenSensors
Part Number Description Engine Type
15733 Oxygen Sensor - OE SmartLink - Universal Fit - Downstream Sensor Two required; 4 Wire; Heated; Check / Replace Interval: 100,000 Miles V6-3199cc 3.2L FI EngDesg GAS
16183 Oxygen Sensor - OE Type - Exact Fit - Downstream Sensor Two required; 4 Wire; Heated; Check / Replace Interval: 100,000 Miles V6-3199cc 3.2L FI EngDesg GAS
16179 Oxygen Sensor - OE Type - Exact Fit - Upstream Sensor Left side; 4 Wire; Heated; Check / Replace Interval: 100,000 Miles V6-3199cc 3.2L FI EngDesg GAS
16167 Oxygen Sensor - OE Type - Exact Fit - Upstream Sensor Right side; 4 Wire; Heated; Check / Replace Interval: 100,000 Miles V6-3199cc 3.2L FI EngDesg GAS
Old Aug 29, 2010 | 12:44 PM
rdw's Avatar
rdw
c32
type the bosch amazon part number in alloxygensensors.com. I can send you pics when i receive the parts. The rear cats o2 sensor now on back order from amazon at .... guess i ordered the last two in stock..... says two to four weeks delivery.
Old Aug 29, 2010 | 12:48 PM
rdw's Avatar
rdw
c32
after looking at the prices....... I replaced all four.
Old Aug 29, 2010 | 01:16 PM
C32/C55 AMG
Definitely send pics, I'm pretty sure they are the same. The price was $80 right? The cheapest I can find them now is $100.
Old Aug 29, 2010 | 01:20 PM
rdw's Avatar
rdw
c32
mine was
1 "Bosch 16167 Oxygen Sensor, OE Type Fitment"
Misc.; $88.46
1 "Bosch 16179 Oxygen Sensor, OE Type Fitment"
Misc.; $79.87
2 "Bosch 16183 Oxygen Sensor, OE Type Fitment"
Misc.; $103.02
Old Aug 29, 2010 | 03:27 PM
clk500
part #for my clk is
15733
16183
if u need then just hit me up
Old Aug 31, 2010 | 10:53 AM
CLKCLK's Avatar
03 C32 gone, 06 CLS55, 16 Tesla X
I got exactly the same codes after getting the ECU retune back from Jerry for the rediness issue with the previous tune. The code doesn't come on right away after clearing, but after driving about a week.
Did you have your ECU retune for readiness issue also?
Old Aug 31, 2010 | 01:59 PM
C32/C55 AMG
Nope, I have not done a tune. The car may have had a tune before I had it, but I doubt it. This problem has been ocurring for a year now, the car will throw a code and then they would go away. I even bought high flow cats thinking that the problem could be the cats, but I was told that the rear O2 sensors are not responding correctly.
I'll be getting new ones soon.
Old Aug 25, 2014 | 09:12 PM
MRDZR1's Avatar
2002 C32 AMG & 951 Turbo
I have this exact code! I know! Old topic, I'm also a new Mercedes owner and new on this forum, but my question is simple, did your code came out after you installed high flow cat's? It usually happen on all JOEM vehicles when you do and only need to install extension adapters on the O2 sensors to fix the issue, so what fixed your problem?
Thx for the answer
Martin
Old Aug 26, 2014 | 10:29 PM
MarcusF's Avatar
2002 CLK430
@Martin
Doorman sparkplug non-foulers definitely correct the error on secondary O2 sensors. Just like any other car, screw the extension into the secondary O2 sensor port on the exhaust, then screw your O2 sensor into the extension. It moves the O2 sensor out of the exhaust stream, raising the O2 content, and the light will go out. The fix is about $10 for both sides. I have them on my car and haven't had an O2 sensor CEL in years.
Old Aug 28, 2014 | 07:26 AM
MRDZR1's Avatar
Originally Posted by MarcusF
@Martin
Will do! Thx!
