WTB: Supercharger pulley bearing
Old Sep 5, 2010 | 02:10 AM
Koru_Kinshi's Avatar
2018 E63S AMG, 2003 SLK 230 Sport, 2004 SL 600, 2006 SLK 55 AMG, 1998 E320 Wagon
It sounds like my SC bearing on the Code 3 pulley is going bad again. It's been about 35,000 miles, I'd say. Does that sound about right for the NSK bearing to start going bad?
If I confirm it's bad, which I'm 99% sure it is going bad, I need to buy one. Anyone have one they want to sell?
Old Sep 5, 2010 | 08:23 AM
320 dreamer's Avatar
2003 porsche 996 turbo
hpautowerks has the bearing around 50$
Old Sep 5, 2010 | 01:30 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
needswings has it too.
http://www.needswings.com/Products.a...E-1CD09899D261
Old Sep 5, 2010 | 01:47 PM
Fifty bucks??? Jeez, that's a lot more than I paid for the last one. I paid around $25. :p Oh well. Does anyone have a private party one they want to sell?
Also, is 35K about right for the bearing to wear out?
Old Sep 5, 2010 | 08:59 PM
did you get it in a group buy? of course you can keep running the failing bearing, im sure it will tell you before it seizes and trashes the belt and who knows what else. of course you will have saved 50$
Old Sep 5, 2010 | 10:23 PM
No, I bought it private party. :p Well...I suppose it has to be done. It's just a pain. Again...is 35,000 miles about the average wear time? Heh, still don't know if that's normal.
Old Sep 5, 2010 | 10:34 PM
TemjinX2's Avatar
dont u have a code sc pulley? You should make sure if the code3 bearing and the oem sc bearing is the same size. The links we gave you are for the oem sc bearing.
Old Sep 5, 2010 | 10:36 PM
It *should* be the same, shouldn't it? I thought the only difference between a code 3 and a stock was that it was machined down 9 mm.
I wouldn't know where to look and verify if it's the right one. Any suggestions on who to ask?
Old Sep 5, 2010 | 10:41 PM
Never mind, I think I found it. It appears that the sizes are the same. Does anyone know if Nachi is a good company as well? They have a direct replacement to the NSK bearing.
Old Sep 5, 2010 | 11:09 PM
gt4awd's Avatar
2005 Pontiac GTO 6.0 LS2 - Blue
What's the RPM rating on the Nachi? When I was looking into supercharger bearings a while back I remember that one other company provided a bearing that would fit. However, that bearing is mostly used for A/C compressor pulleys, and will not stand up to the high RPM supercharger pulley application. Not sure if the company was Nachi...
Yes...
Old Sep 6, 2010 | 11:06 AM
ML500K's Avatar
C32 '02
Nachi actually makes the bearings for the x55's SC clutch.
Old Sep 6, 2010 | 01:35 PM
Does anyone know what the average lifespan of the NSK bearing is?
Old Sep 6, 2010 | 01:56 PM
35k?
Old Sep 6, 2010 | 09:49 PM
ML500K's Avatar
C32 '02
Originally Posted by 320 dreamer
35k?
sounds about right to me... many factors come into play, the environment where the car is driven, temps etc....
Old Sep 9, 2010 | 10:21 PM
Galodourado's Avatar
C32 AMG
Does anyone knows the NSK reference for this bearing? How much it should be maximum RPM to look for?
Old Sep 10, 2010 | 09:47 AM
ML500K's Avatar
C32 '02
if my memory serves me right, our clutches engages @3000rpm even when pressing lightly... so the bearing actually doesn't spin than fast....
Old Sep 10, 2010 | 10:02 AM
TemjinX2's Avatar
3000rpm is the speed of the crank.
the sc speed is (crank pulley / sc pulley) x crank speed.
154/65 x 6k = 14,215.
So the sc bearing is spinning at 14k
Old Sep 10, 2010 | 10:07 AM
TemjinX2's Avatar
i dont under why you just dont order the nsk bearing. Its been proven work reliably and its only $55.
at 35k per bearing its only costing you $0.0015 per mile.
Old Sep 10, 2010 | 12:30 PM
Fair enough, though it appears it was a false alarm.
Old Sep 11, 2010 | 09:27 AM
ML500K's Avatar
C32 '02
Actually when it's engaged, it doesn't spin. It's only when it disengages that the bearing spins... :-)
Anyways, agreed that just get the NSK...
Old Sep 11, 2010 | 11:18 AM
TemjinX2's Avatar
i sit corrected.
Old Sep 11, 2010 | 03:33 PM
carlluther's Avatar
C32amg
Bearing is available at any bearing distributor. I bought one yesterday for 150ZAR. about 22 USD. I am looking for a charge cooler for my supercharger. Anybody know where I can source one?
Old Sep 11, 2010 | 07:08 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
i've had my IB a/c bearing for ages and they are still good. i still have a spare sitting there thinking because the first time i replaced it with the IB bearing it went out in 15k miles. now i'm well over 40k miles on this second bearing I got.
Old Sep 11, 2010 | 07:17 PM
TemjinX2's Avatar
lol does this mean you just keep the car above 3k rpm more now.
Old Sep 11, 2010 | 08:53 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
no, normal driving as usual.
