DIY: Intercooler Separation
2002 C32 AMG
Hope this helps everyone do this mod. I noticed Drop in Temps after doing this mod.
What you Need.
Hose clamps. 2 sizes 2x3/8 and 2x3/4
Shark Bite Brass Plugs 2x3/8 and 2x3/4 (Found At HOME DEPOT)
Flat Head Screw Driver
Clamps (something to stop the flow of water)
Razer Blade
Zerex G-05 Rad fluid, OR MB radiator fluid. (only a little needed if at all)
1.Start by Clamping both sides of the hose located in RED
2. Cut in the middle of the clamps and quickly attach the two 3/4 plugs, then attach the Hose Clamps on both sides of the hose. (I COULD NOT FIND 2 3/4" PLUGS SO I USED A RUBBER PLUG)
3. Now do the exact same for this hose with your 3/8 and your DONE.
Now your IC and Radiator are both separated make sure you top off what you lost during the cutting.
What you Need.
Razer Blade
So, how do you add or drain fluid in your intercooling system? I guess to add you just unplug the line leading down, and use a funnel to fill. Drain by pulling the bottom line to heat exchanger? I decided cut off valves would be better than plugging the lines. That way I can easily open, and close the system. Found the larger one at Home Depot, and the small cut off valve at a local plumbing shop. I would also recommend draining all fluid once it's bypassed, and instead of anti-freeze use water wetter by redline mix with distilled water for the I/C system. Something I still need to do since installing my DIY bypass...
2002 C32 AMG
over all I made this to be a basic DIY on how to do it. When I find better cut off valves I will update the post.
P.S I was Draining my complete system when I was doing this so it made everything much easier
2002 C32 AMG
I am going to go this route when I install my new HE.
2002 C32 AMG
I found this but they dont make a 3/4"
http://www.hardwareandtools.com/Watt...e-u898117.html
Actually the needswings valves are priced just right. I ended up paying only slightly less finding valves myself. Around $40 dollars... You should be able to source both at home depot but the smaller valve will need an adapter to decrease diameter even more.
I did mine using the Needswings kit which is "very nice" and it took all of less than 5 minutes!!! I ran through 2 heat cycles before turning off the valves!! Nice thing is, with the valves, if I ever want to do a complete system flush, I can just turn em right back ON again.
The only tools I needed were a razor blade to cut the bigger tube that comes off the reservoir and a pair of vice grips to clamp. Only one cut was needed for the larger tube and the smaller one near the radiator was unclamp and reclamp with the Needswings kit.
did this last night, i do notice a slight change in temps, it will rise as you drive the car harder, but they go back down in a minute or two, great DIY mod, thanks
It seems to work. I don't have any empirical evidence. LET made it about 2 years ago and its worked for me. I don't have any empirical CFMs for it, BUT am still of the opinion that you can only intake/shove so much air into the engine anyway and that we are probably at the limit with the intakes we have, due to SC, valve and throttle body limitations.
