C 32 transmission
Old Oct 2, 2010 | 10:21 PM
torobird's Avatar
c 32 amg
C 32 transmission
Got a code for transmission selenoid ,does that mean i have to change them .How many they are? Is it very expensive?
Old Oct 2, 2010 | 10:26 PM
Sonny@Marranos's Avatar
Former Vendor of MBWorld
E55,S500,C200 KOMP,SV300 ,LANDCRUISER SAHARA
Theres many soleniods in the transmission,is the transmission playing up at all ? shifting gears out of the ordinary ?
regards sonny
Old Oct 3, 2010 | 10:20 AM
torobird's Avatar
c 32 amg
Is not shifting good- there are vibrations between the shifts and a noise, but the car is getting good speed at all-is not like not running.
Old Oct 3, 2010 | 10:40 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
maybe its a bad conductor plate? i heard its known to go bad on the w203 5speed transmisisons.
Old Oct 3, 2010 | 11:01 AM
j21importer's Avatar
07 E63, 04 discovery
sounds like the conductor plate is needed. conductor plate failures are very common on any vehicle with a 722.6 transmission.
Old Oct 3, 2010 | 09:58 PM
c32kompressor's Avatar
CLK55 AMG
speaking of transmission issues, i pulled a code yesterday that said, gear ratio incorrect??
Old Oct 3, 2010 | 11:53 PM
torobird's Avatar
c 32 amg
Ohhhh, what is this- have no idea about this parts- is it a part of the transmission and why did i get seleniods codes if the problem is that?What is the function of the conductor plate?
Old Oct 4, 2010 | 12:47 AM
gt4awd's Avatar
2005 Pontiac GTO 6.0 LS2 - Blue
My C32 gets the same pending code when I put it in Dyno mode for some strange reason. In dyno mode the supercharger sometimes will not engage. Not sure... I haven't heard anyone else report the same issue.
Old Oct 4, 2010 | 02:29 AM
alkrstev's Avatar
Silver 02 C32 & White 05 CLK500
Did the code show up as a malfunction on the car's screen or was it hidden and you pulled up with a code reader?
Old Oct 4, 2010 | 02:31 AM
gt4awd's Avatar
Only a few systems are relayed to the MFD as a displayed malfunction. Had to of been a pulled code from OBDII...
