Trunk doesn't "spring" up anymore.
Old Oct 5, 2010 | 10:28 AM
clemson_tiger's Avatar
2006 C55
On my previous '07 C230 when I hit the trunk button on the door or key fob it would spring wide open. Well, the '06 C55 with a good deal more miles than the "new" '07 doesn't spring...it just pops open to a-jar. Any way to grease the arms maybe to fix this? Any other advice?
Old Oct 5, 2010 | 10:38 AM
mikekuriger's Avatar
2010 C63
that's how mine's been since new.
Old Oct 5, 2010 | 12:07 PM
mrobinso's Avatar
2021 Yukon XL Denali, 2017 GLS450 4MATIC, 1993 Chevy Corvette
More often than not my trunk does not 'spring up' either, however, from time to time it still will. Greasing the hinges could probably make a difference - I am pretty sure you would need to remove the trunk paneling to access the actual hinge component.
Believe it or not I also think having a heavy license plate and license plate frame makes quite a bit of difference as well. Once I put on my new AMG frame and new plates when I got the car, the trunk did not 'pop' open as frequently.
Old Oct 5, 2010 | 02:29 PM
moosejaw's Avatar
none
I think you can adjust the tension on the springs in the trunk
My trunk used to fly open until I put a C55 spoiler on the back and it would only pop open.
Old Oct 5, 2010 | 02:41 PM
559EVO's Avatar
2005 C55
My C240 would also spring open but my C55 just pops up a lil, it probably has the same tension but the weight of the spoiler makes a difference.
Old Oct 5, 2010 | 02:44 PM
alboogiee's Avatar
Moose is correct, both sides of the trunk have springs, if you added a euro plate under the us plate and/or have the spoiler there is alot more weight for the springs to 'spring'. You'll have to remove or pull back the carpeting on either side and with vice gripes clamp down on the spring and pull it to a further hole...5 min fix.
Old Oct 5, 2010 | 02:52 PM
thtguy's Avatar
2017 GLS 550
I will have to look into this, Usually when I pop the trunk with my key it is because my hands are full and it would be easier to put stuff in. But then usually when I want to close it my hands are full too... too bad we can't get auto closer like E and S classes
Old Oct 5, 2010 | 02:54 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
lol, I recently started to have the same problem. Only after adding the heavier Black Series spoiler. Now to check to see if the springs can be adjusted
Old Oct 5, 2010 | 02:59 PM
2006 C55
Awesome! I'll be checking to see if I can get my truck to "fly open" like I think its supposed to! I was about to say that maybe all C55's had the issue due to the spoiler, but I just remembered that in '07 all the sport edition's got the AMG spoiler, so that can't be the only reason for the non-spring in our trunks.
Old Oct 5, 2010 | 03:08 PM
97W202's Avatar
2006 C230 6speed/14 C63
set your springs had the same problem
Old Oct 5, 2010 | 05:26 PM
14cue's Avatar
05 C55
I have always had this problem with my 05. Dealer says it's normal. I have a problem with my arm rest as well compared to my old 05 C230, it doesn't incline.
Old Oct 5, 2010 | 06:41 PM
Tump43's Avatar
2014 E350 4Matic
I re-adjusted my springs per this advice and my trunk now springs open.
Old Oct 5, 2010 | 07:12 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
Mine doesn't do it as well and I like it that way. Almost got smacked in the face with my mom's 5 series that did that. I've got arms, no thanks.
Old Oct 5, 2010 | 09:54 PM
thtguy's Avatar
2017 GLS 550
So I am not the only one who doesn't have the incline feature on their 05 armrest?
