Temporary Racing harness
Old Oct 9, 2010 | 01:24 PM
masterianvii's Avatar
LADA 1600
Is it possible to install a 3 or 4 point racing harness temporarily on a C55 without any drilling or replacing OEM seatbelt mounting bolts?
Can it be mounted to child seat mounting points in the rear, and somewhere under the seat?
Usage would be for autocross, where the harness would be installed during the event only.
Old Oct 9, 2010 | 01:26 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
What kinda autocross are you going to that requires that kinda belting?
Old Oct 9, 2010 | 01:52 PM
LADA 1600
At any autocross event where that are turns . The stock seats do not provide enough lateral support, and there is no dead pedal in the car to plant your left foot securely for additional support. So you end up being tossed around with a deathgrip on the steering wheel, and you can't concentrate very well.
In fact any recommendation for being securely planted to the seat would be nice.
Old Oct 9, 2010 | 01:59 PM
Viper98912's Avatar
While I haven't done it or thought it out, if you don't want to drill any holes then you should get a racing seat and fab up some custom brackets to use the stock hardware and locations. Then unbolt it when you're done.
Old Oct 9, 2010 | 02:43 PM
LADA 1600
That would involve much more effort. Plus you still need to anchor a harness somewhere. You wouldn't anchor it to the seat.
The idea is to provide some solution that clips onto existing locations, i.e. existing belt buckles + something on the left side of the driver's seat, and rear left. No fabrication/modification should be involved.
Old Oct 9, 2010 | 07:07 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
stick velcro to the seat and stick velcro to what you are wearing. you'll stick to the seat like no other.
Old Oct 9, 2010 | 08:48 PM
RES's Avatar
RES
2005 C55, 1988 260E, 2000 Chevrolet Silverado
Duct Tape?
Old Oct 9, 2010 | 08:49 PM
LADA 1600
Great idea, though still requires some sort of permanent attachment to the seats.
After doing some searching around, seems like the following solutions are possible options starting from the simplest:
1. Push seat back about 10in, tighten stock belt to engage lock, push seat forward while holding in locked position, until it fits nice and tight. That should help.
2. Velcro belt that wraps around the seat and your chest for lateral support.
3. CG-Lock. Apparently this is some device that forces the lap portion of the stock belt to be always tight.
4. Schroth Quick Fit. Harness that for the most part uses the stock buckles, but still requires two endpoints to be mounted.
Old Oct 9, 2010 | 11:37 PM
Autotechnica's Avatar
2002 C32 AMG
I have a sparco 3 point with a quick detach hooked onto the child seat ancors right at the rear head rests.
Old Oct 10, 2010 | 01:55 AM
LADA 1600
Interesting. Do you have a link to that product? Where does the lap belt attach?
Old Oct 11, 2010 | 06:30 PM
Rick Hohwart's Avatar
2005 C55
No idea how or if it works:
G-Force Torso Harness
Old Oct 11, 2010 | 06:51 PM
Newzchspy's Avatar
PLAID
http://www.cg-lock.com/
All of the auto magazines swear by the CG-Lock!!
Guys got a patent on it.
Old Aug 20, 2013 | 09:55 AM
SilverArrow's Avatar
450SEL 6.9, W210 AMG E55; R129 SL500 Silver Arrow; R129 SL600, R230 SL65, W204 C63
Harness for C55
I noticed your post from a couple years ago. I am looking for a similar setup for with a temporary harness. Are the child seat anchors strong enough? were you using the loop behind the headrest or the isofix at the bottom of the seat? Just wondered if you could give advice based on your experience?
Old Aug 20, 2013 | 05:24 PM
dsp_tdi's Avatar
2005 C55
I have a CG-LOOK and I am very happy!
Also, I have a big custom dead pedal.
Old Aug 20, 2013 | 06:15 PM
Saaboteur's Avatar
eclectic assortment of cars
I want a dead pedal! Where did you get yours?
Old Aug 20, 2013 | 11:03 PM
Thanks!
I will get one of those.... and where did you get your deadpedal?
by the way are you still going out on the BMW Trillium Driving schools? I am just starting but seem to be the only Benz out there. I am also member of MBCA and looking for others to join and enjoy.
Old Aug 21, 2013 | 12:11 AM
ghiaguy's Avatar
C55 AMG, 300D-T & Karmann Ghia
I've been looking for the best dead pedal I could get too- dsp's looks great!
That seat belt tensioner seems really clever as well.
Old Aug 21, 2013 | 11:13 AM
Your signature pictures on the track looks great! Would you allow me to use it on one of our newsletters on MBCA? We are just announcing a Advanced Driving School and Track weekend at Mosport in coordination with BMW Trillium and I was looking for some MB performance pictures but not DTM or SLS ... so yours would be great! Thank you in advance. ...and maybe you would join us or have some more pics...
Old Aug 21, 2013 | 01:16 PM
kent426's Avatar
2005 C55, 2006 Ram 2500 MegaCab diesel, sold 2001 Dodge 2500 Cummins, sold 87 190e-16v, sold 97 e420
Slide the seat back slightly, twist once and then move seat into final position. I track that way and don't have any problems other than my head is jammed in to the liner.
Old Aug 21, 2013 | 04:02 PM
MIKESV8's Avatar
Aston Martin V8 Vantage
i know there are tons of people in the non-AMG W203 section with the C class coupes taking out there seats and putting in non-mechanical racing seats. maybe try taking a look there and see what they have to say too.
Old Aug 21, 2013 | 08:03 PM
dsp_tdi's Avatar
2005 C55
My dead pedal is a home made project
Aluminium plate 4$
Grommets 12$
Crazy glue 3$
Hardware 10$
A lot of my time
I put a back plate to reinforce the carpet and I attached this plate to the braquet on the left side.
I have a couple pics:
Attached Thumbnails Temporary Racing harness-1075.jpg   Temporary Racing harness-1082.jpg   Temporary Racing harness-1119.jpg   Temporary Racing harness-1120.jpg   Temporary Racing harness-1125.jpg
Old Aug 21, 2013 | 08:13 PM
Saaboteur's Avatar
Okay, when are you making more for the rest of us?!?
Old Nov 4, 2013 | 06:09 PM
ghiaguy's Avatar
This!!
Well done dsp!
...i just got my hands on a cg-lock and ill post up my personal experiences with it. Seems that it won't have any problem doing what its made for, but I'm curious how it is to live with in a daily driver.
Old Nov 4, 2013 | 06:35 PM
I tried the CG-Lock and it worked quite well on the track. Held me in place as it was designed and really easy to put on and use. But I ended up taking it off for the street. To restrictive to reach for anything in the car. Also noticed that it would "hang" the seat-belt different when off and slammed the door on it a couple time... not nice for it and certainly not nice for the paint
Old Nov 4, 2013 | 06:51 PM
dsp_tdi's Avatar
2005 C55
+1
Not really good for dd, more for track use.
