Just bought C32, a few technical questions
1. Off-idle surge & Check Engine light: From a stop, the car bucks like someone who can't drive a stick. If I let off the throttle and hit the gas again, it smooths out and accelerates great. If I slow down to under 10mph and hit the gas, it does the same thing, though not as violently. Again, if I let off the throttle and hit it again, it smoothes right out. There is a small amount of bucking at speed but it's barely noticeable. Any ideas on what could be causing this? I plan on taking it to a german specialist or a dealership but I'd like to have a little information going in. I figure it's a sensor malfunction somewhere because of the inconsistency.
2. Alignment: this car needs an alignment in a big, bad way after sitting. I've heard that only MB dealerships have the correct tool to do this. Just want to confirm whether that's true or not.
3. iPod connectivity: I need to get an mp3 player connected to this thing and would prefer to do it on the cheap because of the other problems and the fact that I need snow tires. It does not have a nav system, which I guess changes things a bit. Any advice on how to proceed would be appreciated (though I'm not going to do the work myself, I HATE tearing apart dashes).
4. Snow tires: any recommendations?
Thanks in advance. I'm soooooooo excited to get this car (moving from an 08 Pontiac G6 and purchased this car from my father, who hadn't been driving it for a few years so it only has 88k on the clock).
2. Any place can do an alignment. I piad $40 for mine to be done.
3. Do a search for IPOD to find a third party source to hook it up but i think you would be better off with an aftermarket system. Look up double din units from Pioneer. I like the BT series or the AVIC Series.
4.Snow tires i know nothing about since im from the south. Ask a Canadian.
rocketpig, you know those ipod kits you can get at best buy for like 20 bucks that goes into the tape deck that you can hook up to the ipod? yup. that's what i have.
i put the tape in the tape deck. had to gently force it closed. i have the thin wire up in the top left hand corner (from the driver's perspective) of the tape deck so when it closes, that is where the wire protrudes from. then i snugged it along the carbon fiber lining all the way down to the cup holder. actually looks pretty clean and the wired ones obviously have way better sound quality than those wireless ones
congrats on your new car and welcome to the forum!
I'll look into possibly upgrading the stereo down the road, just not now. The current stereo works just fine for me if I can get an mp3 jack hooked up to it.
I dont think the Audio 20 has a AUX input. In any case check the right side of the glovebox.
Also use the SEARCH function. Items #1-3 has been discussed numerous times.
http://www.amazon.com/Harman-Kardon-DP-1US-Controller/dp/B000BT97UO/ref=sr_1_1?ie=UTF8&s=automotive&qid=1288380710&sr= 8-1-catcorr
