Do i need to get ECU re-tuned after installing an intake?
Anyways, i am waiting to get the sl55 intake and pulley saver kit so i can have everything installed at once. I know i can get away with having the pulley kit and tune without the intake or pulley saver kit for a while, but i rather just wait til i get the pulley saver since the belt is already off for the pulley install and i rather be safe than sorry since the idler bearing seems to be an issue with the pulley kits on our cars.. But my question is, if i get the pulley and NW pulley saver kit installed and tuned, then i install the intake after i get enough cash to buy it, would i have to get the car re-tuned to get more power, or would the intake not make a difference as far as the tune?
Also, is $300 a fair price for the pulley install? The owner of the shop told me it's a 3 hour job, $100 an hour, so $300. They do alot of performance mods for Supras, STIs, 350z/G-35s, EVOs, Porsche, BMWs, and AMG mercedes. The owner was really cool about it. Out of all the shops i have spoken to in the past about my car to get repaired or modded, i never gotten a call back, this guy said hell call me back within a couple of hours with a quote. I asked him a few more questions and he said they basically do everything, such as motor work(internals), quaife and rear-end, transmission work, exhaust and headers fabricating/welding, etc. So if all goes well with the pulley install and tune as far as quality of the work, then i will have all the future work done there. Its hard finding a shop that works on C32s, at least it is for me. Not alot of shops want to touch it. I called two shops a while ago asking for a price on replacing the valve cover gaskets, and they never got back to me.
www.ttmotorsports.com
I already got the valve cover gaskets replaced, i was just reffering to the fact that all the other shops didnt call me back and the owner of broadway perforamcne called me back and seemed cool about everything.
$300 for the pulley install isn't that bad, but I really don't see it taking three hours especially with a bunch of good shop tools around. Take off belt. Remove center bolt on crank. Remove old crank. Replacement of the front crankshaft seal is a very good idea as stated above. I didn't do it on mine and it started to leak... Is the shop doing the PSK at same time for $300? Dyno tune, or just ECU flash?
I figured the idler and water pump pulley were simple since i already replaced those 2 pulleys with OEM ones a few weeks ago. I guess ill just keep em just incase i want to return it to stock or maybe ill sell them, since the pulley saver replaces both of them anyways. But i hear alot of people having problems taking the crank pulley off and couldnt getting the bolt back on with the right torque specs, they did say like 148-150 ft/lbs plus a quarter turn, ill just let them take care of it as well as the tune. And im only getting a ECU flash, not dyno tune. How much more power can i expect, roughly, if i did a dyno tune after the ECU flash?
The quote for $300 was just for the pulley install and tune. The shop owner said they usually charge 50-60 bucks for a ecu flash but since i am going to let them install the pulley, he said he wont charge me for the flash. I bought the pulley+TUNE from EC anyways, so i wouldnt have to pay for a tune. I guess hes just gonna save me the trouble of sending the ecu out and having "down time" on the car. I didnt plan on buying the pulley saver kit at first so i didnt ask for a quote on that install as well. But how hard is it to put that kit on? seems like 2-3 mounting bolts, and replace tensioner pulley and new belt. Im hoping it wont be more than 75 bucks or so for the PSK install.
And crankshaft seal, is that easily replaced once the crank pulley is off the car? If anything, i will order the seal and have them install it as well when they do everything.
Thanks for the input bro.
Torque can be an issue. If you find a heavy duty torque wrench, and attach a longer metal bar though it can be accomplished by yourself. The more leverage you have, the more torque you can apply with less effort.
Crankshaft seal I had dealership do out of stupidity along with timing cover. They charged me over $600 for what I could have done in a few hours. I did so much work on the c32 at the time, and it developed a good oil leak after all my hard work. Didn't want to deal with it anymore... The front seal can be pried right off once the crank pulley is removed. There's a simple shop tool that sets the new seal in correctly.
Pulley saver kit isn't hard to install at all. Maybe a little time consuming, but very easy. It's hard to get at the new passenger side idlers rear nut. That's about it... I worked with Rob at needswings with the intercooler lines being an issue. From what he said they now include the relocation kit I originally made, and showed him.
