Dying battery..?
of other factors. but the only way you're going to be able to determine conclu-
sively is to check the battery. you should check fluid level, check specific
gravity, check static voltage as well as dynamic load test.
all the other issues are causal effects which may/not be directly tied so the
trick is to systematically isolate. i know some folks will gauge poor start, or
error codes and to pay for new battery only to find out the root cause may
have been something else. try to avoid tossing cash into the wind, but to
hand it over only when the cause has been verified.
On my Pontiac when the battery went I was getting check engine lights, abs faults, coolant temp warnings. Cars now a days use the batteries as capacitors for times of heavy electrical load. When it craps out things don't run right.
