Oil Pan Plug vs. Suction C32AMG
Old Jan 10, 2011 | 07:42 PM
ngm01's Avatar
none
Is there a specific reason why MB engine oil and filter change procedure AP18-00-P-010AE calls for a vacuum engine oil remover along with removal of the drain plug to extract engine oil?. Is one procedure technically superior over the other?.. I have no problem with removing the underbody panels and crawling around. Gives me a chance to reflect/ nap away from the hubbub.
Cheers
Old Jan 10, 2011 | 08:14 PM
91RS's Avatar
2016 Chevrolet SS, 2006 Cadillac STS-V
I'm not sure about the C32 and the V6, but my C55 has two drain plugs and using the sucker will not remove all the oil. I would just use the drain plug (or plugs) and skip the extractor.
Old Jan 10, 2011 | 09:09 PM
mkonei's Avatar
05 C55
search is your friend....seriously covered a thousand times here, along with "what weight oil should I use".
Old Jan 10, 2011 | 11:47 PM
Quicktwinturbo's Avatar
CLS, SLK, ETC
When I was in Korea, most mech used suction machine (not a cheap suction machine) to change oil on AMG line ups..
It does the job but I would still prefer good oil drainage.
Old Jan 11, 2011 | 12:15 PM
02C32guy's Avatar
2005 E55
With the placement of our oil filters, I prefer the suction method because it's quick, clean, and I don't have to jack up the car. I can't speak for the C55, but I definitely get all the oil out with my fluid extractor. It has measurements and I'm always pulling out over 8 qts.
Old Jan 11, 2011 | 02:43 PM
JUAN CASAUS's Avatar
2005 E55 AMG
Are you extracting from where the filter goes in?
Old Jan 11, 2011 | 03:27 PM
02C32guy's Avatar
2005 E55
No, I extract through the dipstick tube.
Old Jan 11, 2011 | 03:28 PM
testknight's Avatar
CLS55
I just put the front of the car on jack stands, pulled off the front cover under car (6 bolts or so) and drained it there. You'll want to be sure to get a new crush washer for the dain plug (few cents, the dealer will have them). I got just as much oil out as those who pumped it and didn't have to buy a pump to do the job. Took me all of 30 mins begin to end.
Old Jan 11, 2011 | 03:30 PM
testknight's Avatar
CLS55
Oh and to your question...the specific reason the shop does it that way is becasue you can save a few minutes with one of those pumps...when a shop is doing a large volume of oil changes a year that adds up.
Old Jan 11, 2011 | 04:59 PM
2005 E55 AMG
OK THATS WHAT I THOUGHT...THANKS
Old Jan 11, 2011 | 06:30 PM
320 dreamer's Avatar
2003 porsche 996 turbo
the actual reason for the suction drain is that the drain plug is a one time use plug and req. replacement of the plug and crush washer. the suction methad avoids this step in the drain process
Old Jan 11, 2011 | 09:21 PM
MyFirstAMG's Avatar
2002 C32, 2007 E550 4matic
My dealer uses the vacuum on my E, but drains my C32. I think MB says that the AMGs need to be drained, while other models can be changed via the vacuum method.
Old Jan 12, 2011 | 09:08 AM
testknight's Avatar
CLS55
The plugs reusable. Only crush washer needs changed out (.50 at dealer if you want to pay too much for one)
Old Jan 12, 2011 | 09:51 AM
close but no cigar
Originally Posted by Yacht Master
it is the plugs, they are micro encpasulated and can only be used once.
[IMG][/IMG]
Old Jan 12, 2011 | 05:14 PM
91RS's Avatar
Except that is says it only applies to 211 and 230 chassis. Changed my oil 3 times so far with the plugs and have only replaced the copper seal with no leaks.
Old Jan 12, 2011 | 05:36 PM
i had the same leak on my 32. just an annoying drip. replaced the plug and no more drip. my plug had the same type of sealant on the threads as the new plug.
Old Jan 12, 2011 | 05:38 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
I reuse my plugs as well but have an extra set in case one gets broken or rounded out
Old Jan 12, 2011 | 05:40 PM
i still prefer to get under and look around as i drain the oil. i just replace the plug and crush washer now as a routine.
Old Jan 12, 2011 | 09:16 PM
c32kompressor's Avatar
CLK55 AMG
Did mine today in auto class, drained the oil from the drain bolt. I had to replace the pilot bushing aswell as the pan seal. Drained about 4 courts that way, filled it up with 4 1/2 quarts of oil from the dealer.
