Air pump problem/quesiton
e36 318i, 2004 sti
Ok everyone I know most of you know I have a problem with my secondary air flow.. my air pump. I know this part involves flowing air into the exhaust. Now my question is it fine for me to drive around or can not fixing this problem lead to more problems and possibly damage something? I am currently about to replace it but im just wondering if it can damage in the engine in any way?
e36 318i, 2004 sti
Ya that is wat I just heard. I am ordering the part tomorow lol from a friend. Its oem and is the new improved version apparently. Does $480 sound like a god deal for the air pump?
$500 for the pump isn't a bad deal. You need to make sure it's the C32 pump though. You can buy the relay at dealership first for $25, and see if the pump starts working.
If I remember correctly, you should go to the dealer and have them update the software for your ECU (it's under some service campaign) and then install the relay otherwise it'll burn out again. Don't qote me on it but could have sworn there are posts out there.. I'll post the link if I find it.
Ok found it.. It has the DYI, part numbers, etc...
https://mbworld.org/forums/c32-amg-c...ump-issue.html
2005 C55 AMG
1.) He doesn't have a C32.
2.) You already started a thread about this, and had most, if not all questions answered: https://mbworld.org/forums/c32-amg-c...5-problem.html
e36 318i, 2004 sti
2. These questions are not the same.
You always seem to find your way into my threads and make smart remarks..
Thank you I have heard the only thing that can be damaged later on is the charcoal canister? I am replacing the pump in a matter of days so I think I will be fine.
e36 318i, 2004 sti
Ok everyone yesterday I received my air pump.. I replaced it today at 6. I drove it to my friends house and than once I returned home my air pump would not go off. It continued to run for about 15 minutes. I kept thinking it would just turn off. It started to make weird noises like it was grinding so I popped the hood and took the engine cover off. The air pump started to shoot out smoke from the top and continued to make those grinding noises and than it died.
2005 C55 AMG
Had you listened (read) what I provided in the other post you started, on the same issue, with the same answers, you wouldn't be looking at pump #3. Better yet, had you searched "secondary air injection pump," you would have pulled up the DIY, plus additional information about WHY a second pump might fail.
With the caveat that I owned a C32 (and not a C55), here is a thread I started some time ago regarding a remedy for a P0410 error code due to a secondary air injection failure.
If you are telling us that you installed a brand new secondary air injection pump and that it subsequently burned out and died, the problem can only be related to a few issues:
1. Your secondary air injection relay is bad. That is relay N10/1kO in the fuse diagram from the thread I hyperlinked. A bad fuse (N10/1f65) is usually a cause of the pump not turning on in the first place. It's rather unlikely the fuse is the issue. Nevertheless, test both.
If one can assume that a brand new pump is not faulty, I would state with confidence that a secondary air pump that continues to run upon startup, and subsequently 'dies' is absolutely diagnostic of a faulty relay.
2. The wiring to the secondary air injection pump is buggered up. Again, this is unlikely because the wiring is 'closed' to the plug. If I remember correctly, the plug can only go on in a particular orientation. Check that also.
3. Your ECU is faulty. Again, this is rather unlikely unless you (or somebody else) has been tinkering around with it.
e36 318i, 2004 sti
Mark.D is right - you need to read up on the causes of a secondary air injection pump failure and empirically determine what the issue is on your car (if you don't want to fork out the $$$$ at a dealership).
e36 318i, 2004 sti
I see this is a old letter but do you think the dealership would still honor this?
http://s265.photobucket.com/albums/i...cecampaign.jpg
2005 C55 AMG
I checked with my dealer, and it reads: "certain models of 2003-2006 AMG C-Class..." which I was told included C32, and not C55. But if you DO get the dealer to buy it off, let me know.
For the future, if you had an indy shop perform the install, and it blew up again, you could potentially have THEM pay for pump #3, since they would warrant their work for 30+ days or similar.
e36 318i, 2004 sti
Also about this document that is really bothering me. The guy that had this car before was very (caring) I must say about this car. Well that is what I have heard about him since I have never met him. If there was a recall letter sent out this guy definitely would have fixed this problem.. makes me wonder if im missing something..
Thank you guys for the help.
2005 C55 AMG
Ok I will let u know. Im going to call them tomorrow. That second idea with the idny shop most likely wont work for me since the 2 air pump lasted a couple hours..
Also, a service campaign is not a recall. A recall will address an immediate concern that may have an adverse effect (limit or hinder) on the way a vehicle or component is designed to perform to the end user in service. Service campaign will likely have no immediate impact on vehicle performance, but may be the result of litigation claims with the manufacturer, affect longevity of components, etc.
As to if the previous owner was made aware of the campaign depends on if the vehicle's VIN falls within the range of the campaign. It also depends on if the vehicle was serviced at an authorized MB retailer. If he had the vehicle serviced at an Indy shop, while the work may be just as good, the Indy shop might not have checked to see if there were any outstanding campaigns against the vehicle when it was brought in for regular service.
Call the dealer, reference the campaign, and ask if your VIN falls within the affected range. Tell them you received it in the mail so that they actually go back and check, as opposed to just telling you "no" and then hanging up.
e36 318i, 2004 sti
Service campaigns only affect a certain range of VIN's. So while the letter states "2002-2006 C-Class AMG models..." or whatever, your VIN may not fall within the range specified for the campaign. Since engineering manufacturing changes happen on the fly with a moving production line, certain vehicles will be corrected, or fixed before the leave the plant while others must be corrected in the field / fleet. Especially true of problems originating with ECU or other software components, as they are regularly updated in production.
e36 318i, 2004 sti
called the stealership today. They first told me they would honor the service campaign. They called me back several hours later to tell me that my vin number doesnt meet the qualifications to be fixed as you said. Just called Mb HQ about this... see if i can get anything out of them..
Also my stealership said they would charge me $310 to fix my relay.
I called the company about my air pump and im supposed to get it exchanged.
The relay (if it is the same as the C32) part number is 002 542 65 19. If I can recall correctly, it costs no more than $30. Use the diagram and guide in the thread I linked above and you can do it yourself.
In the event that the part number has been updated or changed, they should be able to tell you that at the parts counter.
Good news on getting the pump exchanged for free.
