FS: Brabus Crankshaft 3.7L
Old Jan 28, 2011 | 07:44 PM
german32er's Avatar
C32 & C63PP, 203CL
hello,
i have to sell two brandnew brabus crankshafts, to build a 3.7l engine M112K
stroke: 91mm
price 400€ (euro) plus shipping
Old Jan 28, 2011 | 08:46 PM
JUAN CASAUS's Avatar
2005 E55 AMG
Can these be used on a C32?
Old Jan 28, 2011 | 09:14 PM
german32er's Avatar
C32 & C63PP, 203CL
this crankshafts are made only for the C32 (SLK32/SRT6), but you need also other pistons to this, but I do not have.
for the M112 NA engines, brabus make other crankshafts for an 3.8l conversion
with an original 3.7l M112 from ML/SL/S-class, and this crankshaft, you can built an 4.0l M112!!
Old Jan 28, 2011 | 10:11 PM
2005 E55 AMG
How much hp?
Old Jan 29, 2011 | 12:47 AM
german32er's Avatar
C32 & C63PP, 203CL
if the environment fits completely as, heads, cams, headers, pulley, are certainly possible direction 450-500-crank-ps.......
Old Jan 29, 2011 | 01:23 PM
Robert AMG's Avatar
Cls63 & C32
Why do you have to change pistons? if you are only increasing the stroke.
from where did you get the SC inlet?
Old Jan 29, 2011 | 01:44 PM
Dingleberry's Avatar
Marsaydees
Would the new rev limit be set to about 4000 rpm with this crankshaft?
Old Jan 29, 2011 | 07:21 PM
german32er's Avatar
C32 & C63PP, 203CL
when the hub is increased to 7 mm, then the connecting rod or piston is shorter by 3.5 mm
Old Jan 29, 2011 | 07:24 PM
german32er's Avatar
C32 & C63PP, 203CL
why???
91mm stroke ist no problem to 6500rpm.
the "m156" have 94.6mm stoke, and rev limit over 7000
Old Jan 30, 2011 | 11:57 AM
Robert AMG's Avatar
Cls63 & C32
i was thinking same thing.
you did not find any piston or connecting rod shorter by 3.5mm? with same piston bore or larger piston bore(to 2mm)?
i will search here.
Old Nov 22, 2011 | 10:10 PM
german32er's Avatar
C32 & C63PP, 203CL
up
Old Jan 8, 2012 | 08:17 PM
Tommy_s4's Avatar
ML320, Looking for my S4
please respond to pm or email me
tomnogaro@gmail.com
Old Jan 8, 2012 | 11:53 PM
lizardjack's Avatar
Shelby GT500
And you know where to buy the shorter pistons or rods?
Old Jan 9, 2012 | 09:58 AM
whipplem104's Avatar
1990 300ce supercharged and intercooled
I looked into this for a customer years ago. The ml350 is actually 3.7liters with the same bore as the 3.2l. So if you were trying to do this on the cheap just get a 3.7l and mill the pistons for lower compression. Otherwise just get custom pistons and rods made. You would be looking at around 3,000 for custom forged pistons and rods that could take anything.
I am really surprised that this has not been done more on this platform.
Old Jan 10, 2012 | 04:24 PM
german32er's Avatar
C32 & C63PP, 203CL
with the offered brabus crankshaft, original M113 ML pistons and the original 3.7l block with the corresponding connecting rod there is a 4.0l M112 .....
for more details, see my tread "My Next Step".
Old Jan 10, 2012 | 06:03 PM
Robert AMG's Avatar
Cls63 & C32
So the e55 piston and rods make a 92mm stroke and the brabus crankshaft is for 91mm stroke, So are you sure the 55k piston rods and the brabus crank will fit the 3.7l block? the 1mm difference is in the higher or lower part of the cylinder? also the 3.7L block can handle the increased stroke from 84mm to 91 or 92mm? does the pistons hits the heads? i am interested, the 3.7L engine is in my garage!
Old Jan 10, 2012 | 06:29 PM
german32er's Avatar
C32 & C63PP, 203CL
hi,
the problem ist the rod.
the M112 rods are too long, the rods from M113 have an too small hole for the Crankschaft bearing.
i thing the best way to go is with carrillo (or ohter rod manufactor) to make "costum rods" for this exclusiv m112......
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
