How wide are the wheels in the back of your c55?
Old Feb 23, 2011 | 06:46 PM
MBfinatic's Avatar
e36 318i, 2004 sti
I have been wondering about this and would like to know. Mine are the stock 245`s in the back right now.
Old Feb 23, 2011 | 07:01 PM
chris.bachman's Avatar
a car.
Not sure if you care to know but I just put 265's on 8.5's in the rear of my C32.
Old Feb 23, 2011 | 07:08 PM
MBfinatic's Avatar
e36 318i, 2004 sti
ya im wondering about fitting 285. by the way your car sounds awesome
Old Feb 23, 2011 | 08:09 PM
alpha8a's Avatar
'05 C55 AMG
265s on a 10" wheel in the rear. Stock suspension and it rubs on the inner fenders a little bit over big dips. I'm going to try 275's this summer and hope it doesn't rub too much more than it already does. I don't think its possible to fit 285s unless you do a lot of mods to get it to fit.
Old Feb 23, 2011 | 08:48 PM
JUAN CASAUS's Avatar
2005 E55 AMG
I had 275's and they rubbed alot...going with 265's next on C55 rims
Old Feb 23, 2011 | 08:58 PM
SoCalC55's Avatar
2019 AMG C43
Simple guide
245: Stock
255: best "safe" size
265: will rub with people/weight in trunk, but only minimally
275+: modification needed unless you want major rubbing
personally I have run 3 sets of 255s with zero issues. However, in an attmept for better traction, im going to try 265s when this set is finished
Old Feb 23, 2011 | 09:33 PM
ohlord's Avatar
If not lowered
a 275 should fit if installed on the proper offset 9-9.5 inch rim.
The rim width and correct ET are the key.
You can always roll the arch and massage the bumper.
Old Feb 23, 2011 | 10:26 PM
advans's Avatar
C55 ///AMG, 535xi
255s on a 9.5 SL offset. I ran 275 with a 9.5 33/35 offset it only rubbed with ppl in the car, had rolled fenders
Old Feb 24, 2011 | 04:25 PM
a car.
Thanks, it's broken in now and sounds so good. Having intake work done this weekend that might change the tone a bit.
Old Feb 24, 2011 | 05:32 PM
mrobinso's Avatar
2021 Yukon XL Denali, 2017 GLS450 4MATIC, 1993 Chevy Corvette
Originally Posted by SoCalC55
Simple guide
245: Stock
I think that overall this is good guidance, however, you can definitely run 265s on stock suspension without rubbing and a full load of people and luggage in the trunk. I received a really good deal on a set of like-new Dunlop Wintersport SPs from a C63 owner, which I am currently running. Rears are 265/35/18 and no issues for 4,000 miles of driving this winter. I think the problem with 265s mainly is a result of people with modified/lowered suspension.
Old Feb 24, 2011 | 07:27 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
I love the look and balance of 225/40/18 and 255/35/18.
Old Feb 24, 2011 | 07:34 PM
MBfinatic's Avatar
e36 318i, 2004 sti
im mainly trying to get better traction when launching my car.
Old Feb 24, 2011 | 07:48 PM
b344j07's Avatar
2006 C55 AMG
Same here,
255 should be fine, should of came with 255's from factory.
Old Feb 24, 2011 | 07:53 PM
MBfinatic's Avatar
e36 318i, 2004 sti
mine has on it now 245???
Old Feb 24, 2011 | 07:57 PM
b344j07's Avatar
2006 C55 AMG
Yes, that's stock size, I have the same.
255's at the rears should be fine, they should of came with 255 from factory in the first place
Old Feb 24, 2011 | 08:35 PM
2005 E55 AMG
I'd say go with 265's
Old Feb 24, 2011 | 08:38 PM
kent426's Avatar
2005 C55, 2006 Ram 2500 MegaCab diesel, sold 2001 Dodge 2500 Cummins, sold 87 190e-16v, sold 97 e420
I've got 235/ 275 combo on SL55 rims. What I noticed and hear from other people is that the drivers side rubs more than the passenger side so it sound like a tooling problem. To run 275's, pull out the grinder because mine rubbed where the lower bumper plastic ties in to the quarter panels. The stiffening ribs will need to be ground to nothing. The wheel arches really didn't rub. Fill your trunk up with a couple big bags of cement and back the car on a ramp and stuff a feeler gauge or place masking tape on the inner fenders to see where it rubs.
Old Feb 24, 2011 | 09:15 PM
MBfinatic's Avatar
e36 318i, 2004 sti
ya i may just go with 265 unless there is a safe easy way to go wider.
Old Feb 24, 2011 | 09:31 PM
AMGMIZ's Avatar
2003 EVO 8 612whp(sold) 2005 c55 amg R35 GTR
I am on 275 now
Old Feb 25, 2011 | 09:13 AM
mrobinso's Avatar
As Viper mentioned before, 255s are going to give you the cleanest look. 265s on stock rims will give you a "ballooned" look. Or in other words, your tires will bulge out over the lip of the rim. I have gotten used to it since I had my winter tires installed, but in about a month I am getting my summer tires back on (ContiSports 245/35/18) and I definitely prefer the flush look over the 265s.
Old Feb 25, 2011 | 09:29 AM
thtguy's Avatar
2017 GLS 550
265s on 9.5" Wheels
I got my first and only rub last week when I had 4 adults in the car and I went over a speed bump too fast.
Old Feb 27, 2011 | 02:38 PM
559EVO's Avatar
2005 C55
I rubbed with 265/35/18 on a 9.5 rim only in the left rear side, I grinded the metal attachment clips and no rubbing so far. Might try 275/35/18 or 285/30/18 next, 285/30 is actually the same stock diameter compared to 265 or 275 on a 35 series tire that is taller.
Old Feb 27, 2011 | 09:24 PM
ruben65's Avatar
I currently run 255 in the rear on the stock 8.5" rims, no rubbing at all. Handling, cornering etc... feels much more controlable with the wider tire. The overall rear stance tire edge to tire edge is 68.75" wide with 255 width tires on it.
The stock stance tire edge to tire edge is 67.75" wide with 245 width tires.
I would say the widest you could go on stock rims and no rubbing would be 265, but you would have some noticable buldge over the lip of the rim.
Here are mine on the stock rim.
Attached Thumbnails How wide are the wheels in the back of your c55?-rim_buldge.jpg   How wide are the wheels in the back of your c55?-tire_size.jpg
Old Feb 27, 2011 | 09:37 PM
ruben65's Avatar
More pics with 255 width tire on stock 18"
Attached Thumbnails How wide are the wheels in the back of your c55?-left_tire.jpg   How wide are the wheels in the back of your c55?-rear.jpg   How wide are the wheels in the back of your c55?-right_tire.jpg   How wide are the wheels in the back of your c55?-rear_side.jpg   How wide are the wheels in the back of your c55?-rear_side2.jpg
Old Feb 27, 2011 | 09:53 PM
2005 E55 AMG
Do you have spacers on your car? Does anyone know if I'd need to run longer lug nuts for 5mm or 10mm spacers
