C32 Aftermarket cams
Old Mar 29, 2011 | 10:57 AM
newbenz2's Avatar
86 16v turbo, 02 c32
Hey everyone,
I just cant see spending 1/4 of what the car is worth on kleemann cams or Schick cams. I can machine the cam blanks and have them ground but I was curious if any of you have done the swap knows if a cam card was included? If anyone has them could you post the specs on them? Or if you know what the most lift, durations and overlap we can go with out engines with out modification to the pistons? I'm not worried about the vavletrain due to the fact I'm friends with the owners of Ferrea valves. I want this cam to be really lumpy... Chicks dig bumpsticks... haha
Kevin
Old Mar 29, 2011 | 03:31 PM
c32kompressor's Avatar
CLK55 AMG
SOunds like a good project to me, just dont know where to find the specs. Perhaps call kleeman and as km them the specs on thier cams?
Old Mar 29, 2011 | 03:36 PM
newbenz2's Avatar
Well usually when you buy a aftermarket cam they will give you a "Cam Card" This allows you to set spring heights and make sure you have enough spring for the cam and also timing instructions. Would anyone know what the factory ones are?
Kevin
Old Mar 29, 2011 | 03:49 PM
JUAN CASAUS's Avatar
2005 E55 AMG
Ask Eurocharged since they sell them they should know.
Old Mar 29, 2011 | 04:00 PM
silverjimm's Avatar
04 Crossfire MB 5.0L M113 V8 6spd, 05 Bagged SRT6w/55K AMG V8 ,2016 C300 Sport
THis would be awesome if it can be done.
Old Mar 29, 2011 | 04:03 PM
newbenz2's Avatar
I tried working with Eurocharged a few time left messages to buy parts and never once got a response.. Needless to say ill just do it all myself.. I would rather go a little more crazy then the ones they offer anyways...
Kevin
Old Mar 29, 2011 | 07:08 PM
CLK55 AMG
keep us updated with your journey you got going, if theyre good and show an improvement maybe you should try to produce them?
Old Mar 30, 2011 | 01:22 PM
msheredy's Avatar
MB
There was a possible group buy on the Shricks some years back. I did a search and came up with this screen shot of the specs.
Hopefully this'll give you a decent start point.
Old Mar 30, 2011 | 01:27 PM
saer1one's Avatar
2002 c32 AMG 2012 c250 Coupe
tuned in..
Old Mar 30, 2011 | 03:16 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
cams didn't do much difference in a highly modded car as far as $ to hp...
just my opinion on my ride from the past...
Old Mar 30, 2011 | 03:28 PM
newbenz2's Avatar
I appreciate your honesty, I really just want it to be really lumpy. That is if I dont do a e55 swap into the car. I have a good buddy that only does cam grinding. I can make a set of blanks on the cnc for a pretty cheap price and have them ground for near nothing. As of now its just thoughts and what if's, but we shall see where this takes me...
Thanks also for the specs!!!!!
Old Mar 30, 2011 | 05:05 PM
2005 E55 AMG
I'd just like to swap out the original cams especially if they are factory flawed and I may have an issue with them down the road. So I'm still interested in what you can do these for.
Old May 21, 2011 | 01:23 PM
ImportLabSRT's Avatar
2006 E55 2005 Crossfire SRT-6
Did anything ever become of this? I would be interested in a set of camshafts.
Old Nov 14, 2011 | 07:38 AM
macbryanie's Avatar
Porsche 2004 911
+1
I am in prevention mode now.....
But I cant even find the factory 2003-2004 cams...
" Courtesy of loudandheard" :Here are the replacement part numbers: A1120505301 and A1120505401
Parts.com has them for $626.75 and $609.50....(posted March 2011)
I am usually capable but no luck finding these cams anywhere.
Old Nov 14, 2011 | 09:59 AM
loudandheard's Avatar
C32/C55 AMG
Originally Posted by macbryanie
+1
So parts.com doesn't have them for sale anymore?
I would definitely love some cams if this project ever gets going.
Old Nov 15, 2011 | 05:42 AM
macbryanie's Avatar
Porsche 2004 911
Yes, no luck for the cams at parts.com. I cant find them anywhere.
Old Nov 15, 2011 | 01:11 PM
newbenz2's Avatar
I'm waiting to pull the heads of and measure where the piston and valves are. I need to figure clearance and see if I'm going to put aftermarket pistons in it or leave stockers in.
Old Nov 15, 2011 | 03:32 PM
C32/C55 AMG
Are you thinking of boring out the engine and going with bigger pistons or are you thinking about going with forged pistons and lighter rods? Depending on how you design the cams, you may need to go with different valve springs and maybe titanium lifters.
Any updates on your other projects?
Old Nov 15, 2011 | 04:15 PM
newbenz2's Avatar
As for valvetrain, that's taken care of. I have a very close friend that works at "Ferrea" and I'm getting the best product possible. I want to see what I can make with stock long block. Might just modify the pistons for the valve clearance. As for my car I'm modifying a e55 blower to fit. Pics to come soon. I want to keep stock bore and stroke.
Kevin
Old Nov 15, 2011 | 04:21 PM
C32/C55 AMG
Kevin
Should be a beast, I think the engine would benefit from ported heads, bigger throttle body, bigger fuel pump, and injectors.
Old Nov 15, 2011 | 07:27 PM
430's Avatar
430
SLK32
+1
I have a set of stock cams from my 2003 SLK32 with ~27k miles on them. If you are interested make me an offer. I installed a set of schrick cams.
Old Nov 15, 2011 | 08:37 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
How you liking those? Notice some good gains?
Old Nov 15, 2011 | 09:20 PM
430's Avatar
430
SLK32
I do like the cams and them seem to open up the top end for some nice gains. That being said I do not have a dyno to back up my claims. That being said I would do the needswings modified manifolds before I did the cams. The manifolds were not around when I did the cams but I now have a set on order.
