Calling out Juan C...
He had C3 with C3 H/E. I had 185MM on stock H/E separated. Bad heat soak...
HP wise, the Code 3 on my car was comparable to a 181 , the 185 gave me a lil more oomph BUT the bearings were squealing like pigs. This was before NW introduced the PSK.
And no, I'm not afraid of the 185. Besides, I kinda lost interest after seeing the maintenance required on it. I want my car to make it to 250K miles without too much trouble.
So far she's been driving beautifully and wicked fast. Best kill to date from a dig was a brand new SS with an exhaust system. Unfortunately, a majority of the people with Ferrari's and such don't race. They just pose.
I was beat down by a 997 Turbo, but I expected that one. :p I just wanted to see how I'd do. I may finish off the power mods with a bigger throttle body, then call it a day.
Yes, those TT Porsches will get you every time. I'd even be intimidated if I had a modded C63 since they hook up so well with AWD that they just GO!! I've seen reports of 0-60 in the 2.5 range with overboost and launch control with the 2010-2011 TT!! CD and MT have those doing high 10s stock at about 130 MPH (this is stock!!) Out of the blocks a TT will get you by 2-3 car lengths and its get worse from there!!
As an aside, the Code 3 wont give quite the boost of the 185, however, the races I've had with 185s at Morrocco were SO close with the Code 3 that it almost came down to driver skill and launch (I've never run drag radials and my 60 foot time suffers accordingly as I cant launch and hook) . I still think the 185 is a lil bit quicker though. Not enough for me for the trade-offs.
Get you some Hoosiers and rims and you're good to go. Makes all the difference in the world. Just watch your axles (ask Lenin)!!
I ran into a guy with a nice black C55, but he didn't want to have a friendly run due to oil leaks and low oil level
So far my races with CLK55s and C55s always resulted in the 32 winning by 3 car lengths and still pulling at 100 mph.
That's pretty typical
(unless its a Kleemann or another SC'd C55 of course)
....if i were to do it all over, i think i'd do a 181 with a machined down s/c pulley to match the specs of doing a 185 kit
why? if you do a 178 and machine down the pulley to 185 specs, you may get more belt slip. if you get the 185 and keep the stock pulley, you have a decent amount of rotating mass on the crank. 181 + machined pulley sounds good to me. less rotating mass on the crank = less hp lost....and with the same specs as 185 once the s/c pulley is machined down, i think ur golden....maybe a little more power
thoughts?
thoughts?
There's more than one way to skin the cat here................
