C55 Engine Wiring Diagram
Does anyone have the engine wiring harness diagram and the ECU pin out map for the C55? I believe the ECU is Bosch 2.8 ME. I am trying to hard wire the Split second controller which will allow me to adjust the fuel map table and i could not find the diagram any where. Your prompts response is highly appreciated. Thanks
Wow more than 300 viewers not a single word? Our ECU is The Bosch 2.8.1 and i am looking for Control unit N3/10 ME-SFI control module pin out assignments
Thanks for your help..By the way, How is the AEM F/IC unit? Would you be able to adjust the ignition timing as well?
