Can I test my amplifier?
Old Apr 26, 2011 | 08:59 PM
papasmurf's Avatar
C32 AMG
Amplifier got wet, and before I buy another one I am curious if there is a way to check if its still alive and working?
I removed it today, and the fuse seems to be fine, but I am electronically stupid, so any help would be appreciated.
Thanks!
Old Apr 26, 2011 | 09:10 PM
MIKESV8's Avatar
Aston Martin V8 Vantage
Thanks!
there is a way to make it turn on by using a 12volt transformer and hooking up that way with the remote, ground, and hot, but the issue is how would you know if it were on? aftermarket amps have LED's on them to notify you, these probably don't.
Old Apr 26, 2011 | 09:21 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
Before you do, I suggest you take it out, open it up (if possible) and dry it out with a hairdryer.
Old Apr 27, 2011 | 02:43 AM
ruben65's Avatar
More Important question... Is it the factory Amp, and how did it get wet in the first place? The factory Amp is hidden behind panels in the rear of the car.
Old Apr 27, 2011 | 01:02 PM
papasmurf's Avatar
C32 AMG
It is the factory amp, and there was a leak from the push pins that go into the part of the trunk and it got wet.
Ill have to look into that, thanks
Old Apr 27, 2011 | 03:25 PM
c32used's Avatar
LET C32 2002
Talking
well your sounds will be off or very low
Old Feb 5, 2012 | 04:53 PM
jneal3110's Avatar
04 C32 AMG (sadly sold), 05 CLK55 Cab, 08 R350 4Matic, 15 GLA250 (sadly bought), 75 VW Westfalia
Just bumping this thread, I lost my amp to a trunk leak too (having it repaired), had my wife drive the car thru a car wash while I laid down in the trunk with a flashlight and all the trim removed, and saw that the leak really wasn't coming from the push pins holding down the plastic - it came pouring in from sheet metal joints in the corner, upstream of the push pins. I disassembled the trunk seal/trim, and figured that the leak was getting in under the rear glass or along the seam in the corner. The car's never been wrecked, and the amp repair shop said they get a lot of these amps with water damage, so I'm going with the assumption that it's common in W203's and a design flaw. Anyway, I've caulked with window sealant and am hoping that does the trick, don't want to pay another $250 to repair the amp...
Pics attached.
Attached Thumbnails Can I test my amplifier?-dsc09476.jpg   Can I test my amplifier?-dsc09477.jpg   Can I test my amplifier?-dsc09478.jpg
Old Feb 8, 2012 | 08:56 AM
irokwrx's Avatar
Mine 03 C32-Hers 04 c32
I can just sell you mine for dirt cheap. I just did a new head unit and removed my amp cd changer and head unit. I see what people are charging for these and I think its way to much for another Benz owner, we get raped enough at the dealer. Pm me if you want it!
Old Aug 31, 2012 | 12:47 AM
joeytogo's Avatar
2005 c320 w203
w203 amp problem HK logic 7
Hey,
I have a 2005 MB c320 with the Harman Kardon Logic 7 system. I get no sound from the system even though all of the lights on the unit and functions appear to work. I think my amp is bad! Where is the amp in my car? Is it in the passenger side of the trunk? Does anyone know where I could get a new amp or have mine repaired?
Old Aug 31, 2012 | 07:45 PM
MIKESV8's Avatar
Originally Posted by joeytogo
Hey,
i say go aftermarket!
Old Sep 2, 2012 | 10:25 PM
joeytogo's Avatar
2005 c320 w203
Aftermarket sound system?
If I went aftermarket wouldn't I have to replace the whole system including the speakers?
Old Sep 8, 2012 | 01:15 AM
joeytogo's Avatar
2005 c320 w203
Becker Auto Sound wants $700 to fix my amp!
Becker Auto Sound wants $700 to fix my amp! Does anyone know of any alternatives? I don't think I can go aftermarket without having my entire system replaced.
Old Sep 8, 2012 | 04:59 AM
KJI3jflarryfe93's Avatar
why don't you buy a used one on ebay, helluva cheaper than getting robbed by repairman
Old Dec 4, 2013 | 10:14 PM
Quickvr4's Avatar
05 C55 AMG
any more leads on having these amps repaired?
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
