Headlight question
Old Apr 27, 2011 | 11:16 PM
JUAN CASAUS's Avatar
2005 E55 AMG
Headlight question
My left headlight isnt working and I've switched out two other bulbs and still nothing. So its either my ballast out igniter...does anyone know how to test which one it is?
Old Apr 28, 2011 | 07:28 AM
Dingleberry's Avatar
Marsaydees
assuming you have xenon...
pull out both headlights and swap the ballasts (found on the bottom of the headlight)
Old Apr 28, 2011 | 09:14 AM
2005 E55 AMG
Oops...sorry. Yes I have xenon. Does anyone have an extra ballast or igniter for sale?
Old Apr 28, 2011 | 11:53 AM
saer1one's Avatar
2002 c32 AMG 2012 c250 Coupe
Try ebay.. Ive came across some for $80..
Old Apr 28, 2011 | 09:15 PM
05Silver55AMG's Avatar
2005 C55
I got a used ballast from a spare headlight I bought when my igniter when out. $50 and its yours.
Old Apr 28, 2011 | 09:54 PM
2005 E55 AMG
Do you have the igniter too
Old Apr 28, 2011 | 10:40 PM
2005 E55 AMG
Do the C32 s use the same igniter and ballast as the slk32?
Old Apr 29, 2011 | 09:48 AM
Marsaydees
for the igniter, you'd have to disassemble the headlight itself. this requires taking off the front which is glued.
if you search, you'll see that there is an igniter "kit" that essentially replaces the connector that clips onto the bulb. i think it's somewhere around $130
there's a higher probability of an issue being with the ballast, though.
Old Apr 29, 2011 | 12:00 PM
2005 E55 AMG
Ok thanks but I thought the igniter was the part that plugs into the bulb itself...am I wrong?
Old Apr 29, 2011 | 12:32 PM
Marsaydees
the igniter from the factory is buried within the headlight. MB offers a replacement igniter kit which plugs into the bulb itself as you say. you just lob off the wires from your old plug and splice them into the new plug with a built-in igniter
Old Apr 29, 2011 | 12:33 PM
2005 E55 AMG
Ok well I definitely need the ballast asap then.
Old Apr 29, 2011 | 12:41 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
http://compdr.net/mb/DTB%20Mercerdes...eplacement.pdf
Old Apr 29, 2011 | 12:51 PM
2005 E55 AMG
So is it more likely the burner?
Old May 9, 2011 | 07:17 PM
2005 E55 AMG
Ok replaced the igniter and switched the ballasts. Turns out its the ballast. Anyone have one? Part number 1307 329 072
