Ok lets try this again people
has different pressures. There has been some debate on the subject, if you look back in the archives.
The door jamb has the following pressures:
normal load - 32 psi front, 35 rear.
max. load - 36 psi front, 39 rear.
The fuel filler door has the following:
under 130 mph - normal load - 29 front, 32 rear
max load - 35 psi front 42 rear
over 130 mph - normal load - 32 psi front, 35 rear
max load - 35 psi front, 42 psi rear
I keep mine at 32 front and 35 rear.
How's that?
Be that as it may, probably 32 and 35 will be OK for you.
I'm not sure how you are rotating the tires if you have the C32 staggered setup (wider at the back). I've been told NOT to rotate the tires from one side to the other, and of course you can't rotate front to back.
BTW I think I might try to find a tire shop that know what it is doing next time!
