H&R lowering springs popping
Bry
The noise was coming from the trunk like a banging metal on metal at every bump.
Anyways, definitely check your sway bar links. As someone who has tracked their car for more than 8 years, I can honestly tell you this sounds like a sway bar link problem. I have an entire box full of broken sway bar links from my previous cars. Anytime I heard a popping sound from my front suspension, it was always a sway bar link.
And no, you can't install a spring unsidedown. It's not possible. The spring will only fit properly on the pearch/pad one way. You would have to be really dumb to make this mistake as the spring wouldn't seat properly. All springs are installed with the logos/numbers right side up. If you're really concerned about this problem, again physically check. You don't even need to jack the car up.
BTW, do you have experience installing suspension parts? There seems to be a lot of uncertainties. Maybe you should have let a shop do the install. Some suspension components are sensitive to correct torque specs as well.
Bry
My problem came right after I jacked the car up. I say take off the strut and revise the work.
BTW, just because the endlinks were fine before you installed the suspension, doesn't mean they won't break right away. I've broken endlinks many times instantly after installing new springs/struts. If they're already worn, putting added stress from lowering the car can damage the endlinks.
If you're fairly confident that you've installed everything correctly, I'm still pretty sure endlinks are the culprit.
I've attempted to install my AMG springs unsidedown. They would not seat properly. I can't see H&R springs being different in design as they would have to be the same in order to fit properly. Like I said, most/all springs mount with the logo/part numbers right side up. Easy to check.
good luck,
Bryan
