Broken Satellite Radio Control Module!!
What should I do? Does anyone have any better options?
al
The module is located in the trunk directly forward of the spare tire. There are two "pins" to pull up located on the forward left and right edges of the trunk mat. Just lift the front corner of the mat up and you will find a black button. Just pull up the two buttons about a quarter of an inch and then just remove the trunk mat. In the middle of the trunk is the satellite module. You can check this # and make sure it is the one you need. BTW, now that you have read this, I can only swear to this for a 2009 C 300, but hope it helps.
al
