air injection pump ?'s
My question is, would it harm the cats by not having this? I know it only works for 30 sec or so on start up, but its just an issue i haven't heard anybody say anything about. Maybe somebody has some insight?
I also never hear anybody talk about just removing it. When people burn them up or they go out, they'll spend the $$$$$ to fix it. If it didn't matter, i would figure people would just not fix them.
BTW i have no emissions testing.
small code reader and turn the light off
Where are you planing on running a resistor?? The engine management dosent even monitor the air pump but what it does monitor is the rear 02s or the downstream o2s... at start up it injects air to warm the cats up faster so the readings of the rear 02s must drop below 40mV or a cel will show..
what can be damaged?? for first the rear o2 sensors ( if running both cats still) will be damaged... also in some instances the rear cats get loaded up with fuel and can cause problems.. are there ways to get around all this yes not simple thought
