Ghostrider P1 Performance camber kit installed..
Old Jun 25, 2011 | 10:30 PM
saer1one's Avatar
2002 c32 AMG 2012 c250 Coupe
I installed Ghostrider's rear camber kit this morning, easy to install, easy to adjust and great quality. I left them the same length as the stock arms as I will be installing the #4 pads in the rear, then adjusting to the most possible positive camber I can acquire without any rubbing. I have read in multiple threads that the c32's came with the rear #2 pads out of the factory. I initially intended to install the #3 pads but found out today that my car already has the #3 pads installed therefore going with #4. Will continue to update with pictures.
Old Jun 25, 2011 | 10:35 PM
Heavens1st's Avatar
Silver "02" AMG C32
My 02 C32 had #3 pads stock
Old Jun 26, 2011 | 03:43 AM
AMG3.2's Avatar
C63 AMG, P30
what are these pads that everyone keeps talking about?
Old Jun 26, 2011 | 10:56 AM
Autotechnica's Avatar
2002 C32 AMG
Different thicknesses of springs pads used in the rear to adjust the ride height. Basically, these pads are used in many different mercedes models and can be used to rake or level out a car when using different springs.
Old Jun 26, 2011 | 10:57 AM
Gramma_Benz's Avatar
2002 C32, 2012 S550
AMG inserts that protect your underwear once over 150mph...
Old Jun 26, 2011 | 11:12 AM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Originally Posted by saer1one
..I left them the same length as the stock arms..
How much camber were/are you running?
Mine achieves relatively even wear across the tires’ treads with ~ -1.4° and 0° 40'(±05') total toe. :nix:
Old Jun 26, 2011 | 11:44 AM
AMG3.2's Avatar
C63 AMG, P30
Oh I thought so...
Thanks, that makes sense!
Old Jun 26, 2011 | 01:49 PM
saer1one's Avatar
Haven't taken it in for a wheel alignment yet. I plan on installing the #4 pads first then to the alignment rack. Im having inner tire wear in the rear, in a matter of 2 years the insides of the tires have gone bald.
Old Jun 26, 2011 | 10:35 PM
splinter's Avatar
Super Moderator
IIRC you’ve RENNtech springs. Its aft end shouldn’t be too low.
Not going to second-guess a competent alignment technician, although he ought be aware our C’s rear suspension bushings deflect toward toe-out during
brake and -counterintuitively- acceleration loading, irrespective of static ride height.
Two years from your rear tires? Mustn’t be a daily driver.
Old Jun 27, 2011 | 09:34 AM
saer1one's Avatar
Great information splinter..!! I'll make sure and take this data to the tech..
Old Jul 4, 2011 | 10:53 PM
splinter's Avatar
Super Moderator
Fitting fresh Michelin PS2s fore and aft mañana. Another ~$1000 frittered away.
Excellent performance - and they’re consumed evenly.
Old Jul 5, 2011 | 05:24 AM
saer1one's Avatar
Question
A well $1,ooo spent in my book.. I am currently running on Nitto NT555's which I am happy with but I was contemplating on Michelin PS2's which are on my stock 17's. Do you track your car..?
Old Jul 7, 2011 | 12:16 AM
splinter's Avatar
Super Moderator
..Do you track your car?
Yes. Our local Michelin dealer recommended fitting their new Pilot Super Sport.
Ostensibly conceived as the next generation PS2, they’re noticeably more responsive. :)
