It was bound to happen... Tranny problem
Has anyone opened up their tranny to fix this sensor? I'd like to do the repair myself so that I'm familiar with the tranny internals. Any help or advise would be great.
thanks,
Mike
Found this thread from Benzworld.org hopes this helps..
http://www.benzworld.org/forums/w140...tor-plate.html
electronics kit (part number 140-270-11-61) - $280 @ dealer, got on ebay for $165
transmission pan gasket (part number 140-271-00-80) - $15.00
Trans Pan Drain Washer (part number 140-271-00-60) - $2.91
Transmission oil filter (part number 140-277-00-95) - $15.97
Lock pin (part number 140-991-00-55) - $2.91
Connector Bushing (part number 203-540-02-53) - $18.20
I'll also be replacing the brown top solenoids with blue tops. Pics will follow.
I replaced that black plastic electric piece, and replaced my brown tops with blue tops. I also noticed that my wiring harness was oily. I replaced the wiring harness bushing as well. Now I just need to put the fluid back in and see if it actually works.
I finally brought my C55 to the dealer to have the TCU reactivated. I've driven the car about 50 miles on freeway and streets and here are my initial impressions:
1 - street driving in S, it's too jerky. both upshift and downshift is jerky. full throttle shifting is faster than stock, but not harsh at all. feels like it should shift that way stock.
2 - in C mode, it's a little smoother. the 2-1 downshift doesn't happen so that's a little better.
3 - on freeway, downshifts are too fast. the engine doesn't rev up before the downshift happens so it has a noticeable jerk before it takes off. It's not as bad in C mode. If I am in M mode and floor it, then downshift, the engine revs up quicker and the downshift is crisp and power comes on instantly. In S or C mode there is some engine lag. The lag is noticeable with the stick transmission as well, but it's masked by that ultra slow clutch release. There may be some tranny learning going on so I'll have to report back in a few weeks to see if it's better.
What I'd really like to do is get the TCU remapped. I'm trying to find a good vendor for this. If I could get the stock E55 shift behavior in C mode, and the crisp shifting in S mode, AND get the downshifts softened, that would be amazing. If not, I'll live with this.
One thing I did notice is my torque converter lockup is better. Before, on the freeway, I could give it about 2/3 throttle (just enough that it accelerates without downshifting) and the RPM would raise 200 rpm or so due to slip. This behavior is gone. I can put it in M mode and floor it and the RPM doesn't budge - that is until the car actually speeds up. I think this mod will help get more accurate dyno runs.
So, does anyone know of any TCU programmers?
Mike, speak to Mike (HooleyBoy) and MBH. He's been around this block more than once with the blue tops and knows the issue. I believe that a TCU reprogram will not alleviate the issue. He did his on the old C55 and describes the exact same issue that you describe with the Blue Tops. I think the only way to get it back to "normal" if you will, is go with the old brown tops. You've already repaired the sensor issue, why not just go back to brown tops??
The blue tops are needed to increase the line pressure. A TCU reprogram can be used to reduce the pressure for certain operations. What Mike did was attempt to increase the pressure via software, however the brown tops were already maxxed out. Switching to blue tops actually allows the pressure to increase which is what allows the clutches and other components to grab tighter. The E55 has the same valve body but has different programming. For the E55 guys to get the faster shifts, they only need the TCU reprogram since they already have the blue tops. Some C55s also have blue tops stock.
Jerky and abrupt during light throttle shifts with no discernible improvement at WOT. Ditched ‘em shortly thereafter.
Judicious PWM line pressure and TM tweaks worked wonders.
photo credit MJ50
