What do you think about a Twin turboed C55?
Old Oct 6, 2011 | 05:36 PM
  #101
dre5373's Avatar
2006 C55, 1995 C36
Originally Posted by mkonei
You can source just about everything except the turbo from here --> http://www.mandrelbendingsolutions.c...let/StoreFront
Funny...my C55 is at MBS right now getting the exhaust welded up I had them cut out my secondaries before I bought the Kleemann headers and dual exhaust. Pretty chill guys and do clean work IMO
Old Oct 6, 2011 | 07:34 PM
  #102
mkonei's Avatar
05 C55
take pics!
Old Oct 6, 2011 | 08:38 PM
  #103
betrezra's Avatar
C63 507 AMG DA Car #19
Uhhh MSH.... cory at kleeman told me about that gutted klee box.. it was a gutted klee box... no custom half..... just removed the rotors (from what I gathered).
In any case.... you can figure something out...... if you are motivated for SPEEED!
Old Oct 6, 2011 | 08:50 PM
  #104
MBfinatic's Avatar
e36 318i, 2004 sti
I would rather use the stock box and gut it out.
Old Oct 6, 2011 | 08:59 PM
  #105
dre5373's Avatar
2006 C55, 1995 C36
take pics!
I'll try, but I probably won't be picking it up from MBH. Had a friend who owns one of the sickest SL55's I've ever seen install the headers at his shop (A-1 Transmission right down the street from MBH).
Back on topic, does the Kleemann sc kit replace the stock MAF? Or is everything needed to run the sc included in the Kleemann tune? I guess what I'm asking is would whatever modifications are made to allow for the Kleemann sc install work with a turbo setup?
Old Oct 7, 2011 | 02:44 PM
  #106
MBfinatic's Avatar
e36 318i, 2004 sti
I hope the engine can handle a T66 turbo on 7 psi.. Maybe do some other upgrades later on to be able to have more boost.
Old Oct 7, 2011 | 05:03 PM
  #107
msheredy's Avatar
MB
Interesting, seems like a waste of a good blower but cool build nonetheless.
Old Oct 7, 2011 | 09:45 PM
  #108
betrezra's Avatar
Agreed MSH..... from what I understand the owner has a ferrari invested in this build..... so coin not a factor in the build......
I would probably do the gutted stock intake and run a air-air intercooler in the front of the car like the 4 banger imports...... you get good heat reduction in intake charge with a quality air-air i/c. Plus no extra coolant lines to run, no h/e pumps etc...... no heat soak of the h/e coolant media...... etc...
GL.
Old Oct 9, 2011 | 01:15 PM
  #109
MBfinatic's Avatar
e36 318i, 2004 sti
So apparently I have to put forged pistons since my compression is 11:1. What do you guys think? I was planning to run 7-8 psi?
Old Oct 22, 2011 | 08:48 AM
  #110
KIWI KEN's Avatar
CLK63, CLK 55 kleemann, Nissan GTR N1
Ideally you would install forged pistons with a compression ratio for the C55 engine with the std rods of 9.5:1. With 11:1 pistons your max boost will be about 7psi whether you use supercharging or turbo charging.
If you are going to turbo charge especially at 11:1 static compression ratio, selection of turbo chargers and turbo charger trim will be VERY IMPORTANT for a good tune. A turbo manufacturing company like Garrett Turbos once you supply your engine specifications will be able to recommend turbos to suit your application. Intercooling is also very important when using turbos and you will need a custom full size intercooler radiator with a minimum thickness of 30mm on the front of the car.
Old Oct 23, 2011 | 09:33 PM
  #111
MBfinatic's Avatar
e36 318i, 2004 sti
Ok thanks for the info!
Old Oct 24, 2011 | 06:11 AM
  #112
tw2's Avatar
tw2
Usually 9:1 gives the best compromise of off boost driveability and peak hp. A T66 is a fairly small turbo for a 5+ liter V8 so you will certainly have boost very low down in the rev range. Just bear in mind that the T series are antiques now. Look for something from compturbo, precision or the new borg warner EFR series. These are all much more efficient and compturbo for example will make whatever you want with triple ball bearing and a billet compressor wheel.
Old Nov 1, 2011 | 11:49 AM
  #113
MBfinatic's Avatar
e36 318i, 2004 sti
I talked to precision and they said this turbo would be the best pick, http://www.precisionturbo.net/Street...PT7175-CEA/273
Old Nov 2, 2011 | 01:39 AM
  #114
tw2's Avatar
tw2
Probably not a bad choice. However it is a huge turbo. Unless you are looking at 6-700+ whp something smaller might meet your power goals while giving you better low down torque (as if you need that with the V8).
I can get you in touch with someone who does compturbo if you want to look at a custom one. He organized my triple ball bearing, billet compressor turbo for my celica, it was about US$1100-1300 I think which is very competitive for the latest in turbo tech.
Old Nov 2, 2011 | 10:54 AM
  #115
MBfinatic's Avatar
e36 318i, 2004 sti
If you could do that it would be greatly appreciated. That sounds like a very good price.
Old Nov 4, 2011 | 12:17 AM
  #116
Ducatic230's Avatar
2009 gmc sierra 1500, 2005 C55 AMG, 2007 SL55 AMG.
What about a twin turbo with the turbos up front like the S63?
Old Nov 4, 2011 | 01:24 AM
  #117
MBfinatic's Avatar
e36 318i, 2004 sti
Please show me how to fit BOTH without having to relocate everything in the engine bay.
Old Nov 4, 2011 | 02:32 AM
  #118
tw2's Avatar
tw2
Originally Posted by MBfinatic
First off thank you! for all the info. Eurocharge is going to do the tuning on this project most likely. Do you think later on it would be possible to run higher boost? Of course with me adding forged internals and injectors etc.
Yes forged internals and bigger injectors and fuel pump and you should be fine to run higher boost. Unfortunately I don't know much about these engines yet but most large NA cars have adequate fuel lines and fuel rails but this should be checked also. Any fuel rail over 1/2" internal diameter should be fine. If it is a series system with one fuel rail flowing into the other you probably want to make them parallel feed.
Most OEM throttle bodies can accept boost without blowing apart when its snapped shut but this is another potential weak point. Also some NA engines have plastic intake manifolds or plenums, this would not work so well. I don't know how the PCV is setup but this might need rethinking.
I haven't read the whole thread but things to consider are obvious turbo placement which I'm sure would have been discussed. External wastegate placement, electronic boost controller, routing of downpipe from turbo, if running single turbo you will need a cross over pipe from the other exhaust manifold and this has the obvious potential to melt anything around it. These engines are supposedly very strong but you might need ARP head studs and metal head gasket if they don't already come with one.
Can the stock map sensor read boost? Water to air intercooling would be the best in a tight engine bay like these. I would copy the C32 layout if possible. Food for thought.
Old Nov 4, 2011 | 07:50 AM
  #119
320 dreamer's Avatar
2003 porsche 996 turbo
if this is something you truely want to do you may consider talking to bell engineering. corky bell is the true GODFATHER of turbocharging the inventor of the rising rate regulater and there isnt a car built he cant turbo. they are looking at a twin turbo setup as we speak for the crossfire and will be using kleeman tuning technology as they are working in conjunction with brandon. worth a trip to san antonio to use the best. btw they are looking at a price point of 3500 to 4000 for the xfire setup!
Old Nov 5, 2011 | 08:58 PM
  #120
simmy's Avatar
05 c55
I'm going to take a wild stab in the dark here and say it would be best to start out with a 55K block with 9:1 compresssion or take the rotating assembly from a kompressor block and install it in the NA block.
Old Nov 16, 2011 | 07:35 PM
  #121
loudandheard's Avatar
C32/C55 AMG
That's funny that you mentioned that, I just read over the thread at the Xfire forum.
Here's what Cory at Kleeman said to MBfinatic:
So I talked to Cory at Kleemann about the Bi turbo clk55 and he said for about half the price the guy spent to twin turbo the clk55 that I could buy a nice used SL65 AMG.... He also said that the project was to not be duplicated...
This is what Brandon at Kleeman said, I figured what can be done to the m112 can be done to the m113. Sounds a bit fishy to me, but I think it definitely can be done as long as it doesn't eat in to anyone's profits.
Originally Posted by LantanaTX
In the quest for more power for my car, I have made some new friends! i was talking to Brandon who runs Kleeman USA. In talking to him we agreed that a turbo would be a fantastic way to go. I mentioned that turboing a n/a Crossfire hasn't been proven to work becuase of the tuning. He went over the whole fuel management sytem that is used on the Kleeman supercharger system and I was suprised at its simplicity and low cost. Kleeman systems are proven and bullet proof. He went on to mention that the system would work exactly the same on a turbo or supercharger. He also mentioned that a friend of his I should talk to wrote the book on turbo charging. His name is Corky Bell. You can find his books in the book stores and Amazon. Corky is a legend when it comes to turbo and superchargers. You also need to know someone to be able to talk to him. I called and said I was referred by Brandon and was able to get him on the phone. We discussed the project and I am moving foward.
Here is the decision. I can build the system myself and Corky and Kleeman have both offered to consult and provide parts to made it work. I am now confident that making it work great is not an issue. Corky however would like me to bring the car to his shop in San Antonio and let him do the work so that we can make a turbo kit for the n/a Crossfire. If I do this it will cost me more, but you guys will have a complete well engineered kit that will allow you to potentially blow right past an SRT. Corky's stated goal is to sell a minimum of 5 kits. The target price for kits is around $3,500.
To allow Corky Bell to build my kit, I need to find out how much more it will cost and if there is solid interest by at least five people who would do this after it is proven. The only significant difference in what we do to my car and the n/a V6 will be the size of the turbo. If I don't see 5 or more commitments I will do the work myself. So if the system is first rate, runs fastastic and dyno proven and 1/4 mile tested, would you commit? Maybe you have a six speed and want a big performance boost?
Link http://www.crossfireforum.org/forum/...on-needed.html
Old Nov 16, 2011 | 07:52 PM
  #122
MBfinatic's Avatar
e36 318i, 2004 sti
I want a kit from Corkey Bell!
Old Nov 16, 2011 | 08:04 PM
  #123
C32/C55 AMG
What works on the m112 should work on the m113, I can't see it being completely different. The only thing that would need to be different would be the intake, but other than that, it would be the same.
Old Nov 17, 2011 | 11:11 AM
  #124
MBfinatic's Avatar
e36 318i, 2004 sti
Just sold my daily. Its tempting to boost this and have it as a daily..
Old Mar 16, 2012 | 01:30 PM
  #125
EVOII_Racer's Avatar
Mercedes Evo II
thats just f.sick i like very much! (the c55 twin turbo)
