Spacers for the front
Old Aug 11, 2011 | 03:43 PM
pww's Avatar
pww
'05 C55 AMG
Where do you all source yours? My understanding is that our front hubs are only actually 66.5 mm for the first roughly 5 mm, then it gets a bit smaller, which means the spacer needs to be wheel centric, but my spacers I had made don't fit because the part that is wheel centric dips down too much (if this makes any sense)
is the hub supposed to get smaller or is mine worn? (this might be a terribly stupid question)
Old Aug 11, 2011 | 04:18 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
I have H&R's on mine, no problems whatsoever
Old Aug 11, 2011 | 04:19 PM
pww's Avatar
pww
'05 C55 AMG
what site did you go through to order?
Old Aug 11, 2011 | 05:18 PM
2002 C32, 2012 S550
I got them from a member on here, but they sell them on eBay all the time. Just make sure they're hubcentric and for the front. Front/rear are different.
Old Aug 11, 2011 | 10:46 PM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
You might need this type of spacer for the front only.
Old Aug 12, 2011 | 02:01 AM
pww's Avatar
pww
'05 C55 AMG
^Yeah thank you after more research I found the options are either A. the type of spacer you posted or B. A normal spacer with the inner portion of the wheel centric lip grinded down to fit. I ordered some of the above pictured spacers
Old Aug 12, 2011 | 07:41 AM
1stmeez's Avatar
2002 C32 AMG
where to source?
Klinh,
Can you send a source for this type of spacer?
Old Aug 13, 2011 | 12:54 AM
Klinh's Avatar
Originally Posted by 1stmeez
Klinh,
It all over Ebay but the best quality is H&R brand. When order, just make sure that it specify front spacer only. Here's the H&R brand.
http://www.trakplus.com/results
