Overfilled oil
I have been looking for any leaks and havent seen any, and haven't seen any blue smoke from the exhaust or anything like that. Car's performance has improved and seems to be running ok. Other than getting compression and leak tested is there anything else I should look for or do to prevent and minimize damage? Im hoping no serious harm was done since the red warning only came on once and I drained it as soon as I was able to after that.
So how can you minimize it now
Anyway, I would bet that you will be fine. The worst thing that could happen is/was you had a little windage in the sump. AKA crank and rods throwing around the extra oil. Not a good thing, but shouldn't be terminal either.
My worse fear would have been if you were beating the crap out of it, aka 5K+ rpms, as this might cause issues with the bottom end. HIGHLY unlikely that it is, but could.
A quart and a half really shouldn't effect the front or rear main as well.
As far as the compression check, I wouldn't waste the time unless you are having issues.
Drive it, and enjoy it
My guess is you'll probably be fine, but others should chime in here. I believe overfilling the oil can cause oil leaks (as you mentioned) so its good you checked, but worse, having it too full will cause the engine to hydrolock. There is a terrific amount of load incurred when you have multiple connecting rods swinging through 4 inches of oil. Since you didn't drive it too long (200-300 miles) you're probably okay.
I know how you feel though, its scary when you realize what has happened. I had no one but myself to blame when it happened to me though, are you going to take any action against the shop?
Well, other than not doing any further business with that shop and telling local friends that they botched my oil change there isnt a lot of action I can take without repair bills or proof. I drained the oil on my own so I got nothing in writing.
Think gallons, not quarts
PS: Sorry, I just couldn't help myslef.
Oil changes seem simple but I too have had my C32's oil overfilled and the red light come on. Never again will I allow an "regular" mechanic to touch my car!
While these cars are highly reliable (snicker), it is just every so slightly possible that it's a completely unrelated problem. My car has had two things go wrong at once, believe me! I'd say have the ECU scanned and see if it's stored any trouble codes.
I doubt the excess oil is the reason.
The only damage I've seen from excess oil in a 5.0 mustang... (that's my only data point).... was leaky seals due to excess pressure........... this was a on mustang...... no other damage to report.
I would drive it and enjoy.
