Question about high idle at startup?
Old Oct 29, 2011 | 03:36 AM
mikev7's Avatar
C32 AMG Ram 1500 4x4 GSXR600R Track Bike
I have a prob with high idleat Cold startup. I've been reading about Benzes that idle high at startup and im getting mixed results as to the cause and fix. My car not only does it at sold start but it also does it sometimes when I park and put it in neutral. The rpm will run high then slowly decrease to normal idle. It can't be a old cat causing this if the car is at operating temp. How can I fix this?
Old Oct 29, 2011 | 11:57 AM
mikev7's Avatar
Bump.
Old Oct 30, 2011 | 03:47 PM
mgiannetto's Avatar
'06 C55, '14 Audi S4, '09 Range Rover Sport, '07 Lexus ES350,
How high is the idle? How long does is stay high and does it drop after 30 seconds or so. More color/specificity would help.
Old Nov 6, 2011 | 03:45 PM
mikev7's Avatar
Here's a video.
http://www.youtube.com/watch?v=ojclBJrztVM&sns=em
Old Nov 6, 2011 | 04:25 PM
03MBC32's Avatar
2003 C32
I get the occassional high idle after running the car fully warmed up and putting it in neutral. This has been happening for years. Seem to happen more if I've had a few aggressive throttle inputs within a minute of putting the car in neutral/park. No codes set. I don't know the cause for this, but I'm not concerned and strike it up as a quirk of German engineering.
Old Nov 6, 2011 | 04:27 PM
mgiannetto's Avatar
That looks totally normal to me.
Mine (a C55) behaves very similarly. It's done that since new.
Old Nov 6, 2011 | 11:51 PM
mikev7's Avatar
it does it when fully warmed up also. sometimes ill pull up in my driveway after a drive, put it in park and...
Old Nov 24, 2011 | 11:13 AM
mikev7's Avatar
Bump.
Old Nov 24, 2011 | 09:36 PM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
For a cold start that looks perfectly normal, If it's doing it when hot and going back to P or N then you may have an issue.
I would be cleaning the throttle body and checking the crankcase breather hoses for leaks. The C32 doesn't have a air mass meter so air leaks dont show up easily but would give you symptoms like that.
Old Nov 25, 2011 | 01:01 AM
JonMBZ's Avatar
06 C55, 09 E350
I had my idle lowered by a friend because of the vibration, but during a cold stat up it's perfectly normal.
Old Nov 25, 2011 | 02:48 AM
pbSalvadorl's Avatar
bmw
Old Nov 25, 2011 | 05:23 AM
Apox's Avatar
'03 C32 AMG
Mine idles high sometimes as well. Never figured out what the deal was.
