Vibration on a 1000rpm
Old Nov 10, 2011 | 04:22 AM
frejo's Avatar
c55T
I have just bought a c55T. I've already had some problems, had to change the ACC-panel among other things.
But now I've got this vibration at almost exactly a 1000 rpms. It's easiest to notice when I'm easy on the throttle. I've read that the motor mounts is a fairly common problem, can this be it? Some other guy spoke about the "turbine"(?), supposed to be something in the tranny?
Do you have any ideas?
(Hope I'll make myself understandable, expressing technical issues in a foreign language isn't always that easy)
frejo
Old Nov 10, 2011 | 02:51 PM
Budget Baller's Avatar
2018 GLE350
Does the car ever "kick" when it shifts around 1000 RPMS? Or only vibration?
Old Nov 10, 2011 | 02:54 PM
frejo's Avatar
c55T
Only vibrations
Old Nov 10, 2011 | 03:04 PM
2018 GLE350
hmm It's not something I'm familiar with. Some of the expert here on the board will probably know more than I do.
There was complaints of the C32 vibrating but it was usually when driving around 40MPH. Turned out to be the drive shaft if I remember correctly.
Old Nov 10, 2011 | 04:39 PM
xxaarraa's Avatar
Multiple
Whats a C55T?
Old Nov 10, 2011 | 05:08 PM
loudandheard's Avatar
C32/C55 AMG
Originally Posted by xxaarraa
Whats a C55T?
c55 Wagon
Old Nov 10, 2011 | 05:27 PM
MIKESV8's Avatar
Aston Martin V8 Vantage
my money is on bad motor mounts, take a picture of them and post them on here and we'll tell you right away. it's very common
Old Nov 11, 2011 | 02:22 AM
mshields818's Avatar
Mercedes C55 AMG
Sounds like motor mounts to me
Old Nov 11, 2011 | 03:16 AM
frejo's Avatar
c55T
OK, thanks.
Is it possible to take pictures of them without raising the car?
In Sweden the motor mounts cost over $ 200, each, and perhaps $ 100 for the tranny mount. I've seen that there are way cheaper alternatives in the States. Is there any particular retailer, or motor mount, that you guys can recommend?
Old Nov 11, 2011 | 11:15 AM
nladam12's Avatar
C55 AMG
Always go with OEM. I believe Bosch makes them. But I have a feeling it is the mounts as well... although there could be something with the trans, but the easiest way to put that to rest is to put the car in neutral and slowly raise the RPM's, if vibrating the same then its not the trans tunnel.
Adam
Old Nov 13, 2011 | 03:21 PM
frejo's Avatar
c55T
Tried Neutral, still vibrates. I'll try to find some motor mounts and get someone to help me change them.
/frejo
Old Nov 13, 2011 | 03:28 PM
C32/C55 AMG
Post some pics of your C55 wagon, we don't get those in the states.
Old Nov 13, 2011 | 03:31 PM
MIKESV8's Avatar
+1
Old Nov 13, 2011 | 09:22 PM
Quicktwinturbo's Avatar
CLS, SLK, ETC
motor mounts and/or tranny mounts
Old Nov 14, 2011 | 03:22 AM
frejo's Avatar
c55T
Adam
Can it be "Boge"? I've found a couple of those on e-bay.
/frejo
I'll try to upload a picture later.
Old Nov 14, 2011 | 10:10 AM
C32/C55 AMG
/frejo
Go with factory mounts, aftermarket mounts tend to not last as long.
Old Nov 14, 2011 | 08:17 PM
crniamg's Avatar
c55 amg gl 450
bad motor mounts
Old Nov 15, 2011 | 03:48 AM
frejo's Avatar
c55T
Yes, I will. But I'm wondering if Boge actually are the factory mounts? Do anyone know this? Also, I'm wondering if anyone has changed the mounts themself and can provide me with a DIY or some info on how to change them in an easy manner.
/frejo
Old Nov 15, 2011 | 03:58 PM
nladam12's Avatar
C55 AMG
/frejo
From my understanding they are Bosch units, I have never heard of that company so I doubt they are factory. I cannot help you with mounts bc I tend to not like getting my hands too deep into the engine. Go to an Indie they should be reasonably priced around $500 installed.
Adam
Old Nov 16, 2011 | 04:06 AM
frejo's Avatar
c55T
Boge is actually a respected company. Earlier, when I had a BMW, Boge made the EDC shock absorbers. I also think that Porsche uses them, at least they did on earlier models.
