Installing Quaife LSD
Sherman
I think it's a tough job for a layman, but I think any competent mechanic should be able to do it. Like I would totally trust my mechanic to do it.
Sherman
I was ready to pull the trigger and then saw the post, now the car is in storage - so I'll revive the buy / install next April. I plan on doing the work myself.
It was going to be my winter project.
Getting the diff assembly in and out of the car is the relatively easy part, the (potentially) really difficult part is installing the new diff into the case without it making too much of a whine. That's where the shims come in. It would be best to ensure that whoever is installing the new diff into the case has ready access to these shims, or else you may be in for a bit of a wait.
I had a helluva time with updating the ring gear on my S2000. I went from 4.10 stock to 4.44s. It basically required complete disassembly of the diff. I didn't trust myself to do it, other than the removal and installation of the entire diff assembly, so I had a mechanic friend of mine do the actual diff disassembly and reassembly with the newer ring gears. It whined all the time, I suppose he didn't do a good enough job, and I had all the OE shims available for him too. When I looked into the EPC for the C55's diff, it didn't list all of the separate parts for the diff, ie. it said the shims weren't available. Rather, it says that you can only buy the whole diff assembly as a rebuilt unit. Boo.
Does anybody know fastener torque for the ring gear bolts and carrier bearing part numbers. My Service DVD and the EPC have nothing on either.
http://www.quaife.co.uk/sites/defaul...ings/QDF9V.pdf
It's pretty simple, dimension L4 is the distance from the ring mounting surface to the bottom of the bearing journal and dimension L1 is the overall distance between the bearings. Bearings are SUPER precise in measurement, so effectively if you put a bearing at each end of 153mm solid surface (L1 spec) and measured the whole thing in length from race to race, it will be exactly the dimension between the snap ring grooves. Dimension L4 is what dictates the backlash. This type of design is simple, but brilliant and doesn't require shims.
Be sure that the shop you use has the expertise do get it right, my indie has done many and got both mine perfect.
As fyi, I bought both my Quaifes from ACG San Diego, they sell it with a complete MB parts install kit (get the kit), they were competitive and easy to do business with.
