C32 AMG 03 supercharger issues
Old Dec 18, 2011 | 02:11 AM
Rizah's Avatar
c 32 AMG
hey guys hope someone can help me out
So today i get out of my car and i hear this horrible sound coming from my supercharger i have been reading around and its could be couple of things the car has 115,000miles. Before i take my car in to be checked i would like to have some idea what i might be looking at spending.
1.Supercharger might be low on oil.
2.Pully
3.Bearings
4.Belts
Thank You.
Old Dec 18, 2011 | 02:14 AM
Rizah's Avatar
c 32 AMG
It sounds something close to this but not as loud. http://youtu.be/YLtk72uj6wU
Old Dec 18, 2011 | 05:32 AM
johnng117's Avatar
2002 C32 AMG
Change your supercharger bearing, and check the idle pulleys. Not expensive.
Old Dec 18, 2011 | 06:11 AM
Budget Baller's Avatar
2018 GLE350
Yup super charger bearing. I had the same issue. It had almost sounded like it was coming from the back of the SC. But after changing the bearing the car has been quite quite quite ever since
If I remember correctly the parts was around 50 bucks and quite simple to replace.
Old Dec 19, 2011 | 01:48 PM
Rizah's Avatar
c 32 AMG
hey guys want to say thx for the help...But i cant find the bearing any where the MBD is saying there are only going to sell me the whole SC and my Import Shops dont have it if any one has a site that i can order the part???
Thank You.
Old Dec 19, 2011 | 03:03 PM
Miniac's Avatar
E55 AMG
http://www.needswings.com/Supercharg...scBearing.aspx
There you go for just the bearing.
Old Dec 19, 2011 | 03:12 PM
03rnc32's Avatar
03 c32
Harold at hp autowerks also has the bearing ($49.00). I bought one from him and it turned out to be my clutch pulley that was bad. just check both to see which is bad. Clutch pulley assembly tends to fall apart where it's riveted together. if you have a tough time I still have that brand new bearing still in wrapper.
Old Dec 19, 2011 | 03:16 PM
03rnc32's Avatar
03 c32
Also, if the pulley is bad eurocharged has a pulley that gives you 40 more hp for half the price. MB wanted $1430. for stock (71mm) assembly and eurocharged (65mm) is $599. you definitely feel the improvement.
Old Dec 19, 2011 | 10:59 PM
johnng117's Avatar
2002 C32 AMG
for the Bearing
Old Dec 19, 2011 | 11:02 PM
johnng117's Avatar
2002 C32 AMG
I would get a new pulley from EC it will come with bearings ready to install. should also consider the ECU & TCU upgrade too.
Old Dec 20, 2011 | 12:05 AM
lizardjack's Avatar
Shelby GT500
Do not mix supercharger and supercharger pulley bearings.
You MBD is right there is no supercharged bearing available, I was looking 4 'em my self and couldn't find anything.
As for the link, it is the pulley bearing.
Old Dec 21, 2011 | 11:08 PM
Rizah's Avatar
c 32 AMG
Well am not sure my self what it might be but i placed a order for the SC bering from the http://www.needswings.com/Supercharg...scBearing.aspx and it should be here in couple of days it would cost me around 3,000 $ for a new SC so i want to see if its only a 45$ problem am going to let you guys knew what happend.
Thx everyone once more for the help.
