C32 First Mod - C55 Y-pipe Air Intake - With GTECH results
I am an Engineer that has owned for last 10 years Subaru STI's. This has included a Japanese import Version 4 and MY06. I have always modded these rides to extract the most out of them. This has included self tuning of OEM ECU's and racing.
Being 45 (ish), my wife wanted me to ditch the boy ricer image and go for something more conservative.....hence the C32 was purchase a few months ago with 32k km on clock.
I know what forced induction vehicles like and so I will be doing the following mods in the order shown;
1. C55 Y-pipe Air intake - (completed)
2. Air induction cooling system - (undecided which way to go)
3. Exhaust - Sec cats or Resonator or both (undecided)
4. Main or Supercharger pulley with ECU re-tune
5. TCU re program
The above mods will be done over the course of the year and I will post results as per this thread when they are completed.
SO...onto the first mod;
C55 Y-Pipe purchased for AUD$165 and installed. I also cleaned the air OEM air filters while I had air boxes open.
First reaction is that part throttle response is much better. I am no longer doing the ECU reset procedure. After comparing results on Gtech, I am getting upto 10 hp more at low end so this explains the better response. 0-60 times down a little from 5.111s to 5.001s. This was with ambient temperature about 10 deg C higher, so I am stoked with result.
Notes on Gtech results attached.
1.Main run (black) is best time achieved as stock vehicle.
2. Other two runs are typical runs with new Y-pipe
3. All runs on same stretch of road, using 30cm roll-out (don't want too much stress on car components).
4. Stock run was at night time at about 15 degC and other runs were during the day at about 25 degC
5. TCU re program
With regards to secondary/primary cats, dont remove the primaries as this has A/F ratio gauge attached and depending on the Maps is used as a feedback loop to trim A/F ratios for optimum fuel economy when running on highway etc. I presume you mean the resonator. Again, gavin looked at the exhaust and reading stuff on the forums it seems like a fairly unrestrictive system. It becomes a personel taste thing regarding sound output. have a listen to the different options on You tube. I will eventually by modifying this also and will post before and after Gtech results.
Just as a side note, by making the intake and exhaust free flowing it helps with the air flow when upping the boost with a pulley. Also be careful of the possibility to run leaner due to the increased amount of air flowing. Not too many WOT runs before doing the pulley and ECU re-tune!
Cheers and enjoy the modding bug!
P.S I would also consider ways to cool the intake air. Huge gains can be had due to a denser air means more air in charge and bigger boom!
I think you mean 55 Kompressor series Y pipe though. The C55 is N/A and has a different Y-pipe.
One question though. Did you just order the Y-pipe or did you also order new hoses etc?
Please find attached my install bible which was originally based on a post in the SRT forum but I have included my inputs based on C32 install. It also has pictures and WIS information also. I am not sure who posted the original DIY guides but most of the credit goes to these guys (I guess they know who they are).
FYI: I bought the complete Y-pipe assembly with hoses.Part no's are in attached document.
Cheers
additionally, to see the full effect, it is recommended to get the tubes and the larger 55k intake boxes since they are (IIRC) 50% larger
My buddy uses it for all the stuff he buys from the U.S, when the company doesn't ship externally.
...anyway, now I'm after a Y-Splitter and connecting hoses, I'll be setting one up. My usual haunts don't have the parts available.
Cheers.
Cheers.
