2002 C32 cranks, but won't start
Old Jan 28, 2012 | 10:17 PM
carigmbamg's Avatar
2002 C32 AMG, 1985 BMW 635 CSi, 2006 Subaru Forester XT, 2007 Nissan Titan SE, 2005 Triumph Tiger
My C32 started yesterday and ran for about 20 seconds before dying. Now it just cranks and never starts. I can smell a slight gas smell from the exhaust, I have no malfunction, fuel pump fuse is OK. I have searched the web for help, but nothing too close to this. The B service was just done last fall, but the car sits a lot these days. It has less than 50K on it. I live a long ways from any dealership, so help would be greatly appreciated.
Old Jan 29, 2012 | 12:46 AM
inflectionpt's Avatar
88 BMW M3, 11 BMW M3 Vert, 04 Porsche GT3
check your cps (crank position sensor).
Old Jan 29, 2012 | 03:58 AM
Budget Baller's Avatar
2018 GLE350
CPS
Get an OBD reader. There's probably a stored code.
Old Jan 29, 2012 | 02:23 PM
carigmbamg's Avatar
I am getting my OBDII out to get any codes, but was wondering how to "check the cps". Is there a way to do this without installing a new one?
Old Jan 29, 2012 | 03:38 PM
2018 GLE350
Usually the CPS going out will throw a code which is enough. But, there is no way of that I know personally to test the CPS other than to change it.
When my CPS went out there was a stored code.
Old Jan 29, 2012 | 04:27 PM
carigmbamg's Avatar
Got ScanTool OBDII connected and got no logged or pending fault codes. The timing was registering as -54.
Old Jan 29, 2012 | 06:44 PM
lizardjack's Avatar
Shelby GT500
Can you actually hear the pump when you switch the ignition on?
Old Jan 29, 2012 | 07:55 PM
carigmbamg's Avatar
Assuming the fuel pump is in the back, I opened the rear seats up and as I turn the key just short of starting, I can hear what sounds to be a relay in the trunk click, but no whir of a pump. I checked the fuel pump fuse yesterday and it looked good. I unseated and reseated all the relays in the trunk too.
I thought that I read in a post, that if the CPS was bad that it would disable the fuel pump. Is that true?
I have found a Bosch 0261210170 Reference Mark Sensor (Crank Position Sensor) on Amazon for $45.
Further help is appreciated. Thanks
Old Jan 30, 2012 | 08:49 PM
lizardjack's Avatar
Shelby GT500
Most likely the pump is dead or connector on the rear SAM melted.
CPS has nothing to do with the pump, it does manage the injectors though.
Check for power supply to the fuel pump. I cannot believe that both main and aux pumps went down at same moment.
Old Feb 2, 2012 | 05:27 PM
ScottW911's Avatar
Super Moderator Alumni
a C32 AMG & S-Works Tarmac
What was the outcome?
It sure sounds like the CPS to me. I had the same issue a few months back.
I had an interesting side effect from replacing it here:
https://mbworld.org/forums/c32-amg-c...sion-jerk.html
Read through it and you will find the cheapest place to order a CPS and the codes the car should throw.
Old Feb 3, 2012 | 12:59 AM
carigmbamg's Avatar
Just got the CPS in the mail today, still waiting on the E8 torx socket to arrive, plus I have to tile the bathroom walls and floor before I can start (says the boss). I will post as soon as I can get the car up on jacks and try my hand at CPS surgery.
Old Feb 3, 2012 | 08:58 AM
lizardjack's Avatar
Shelby GT500
Waste of time/money IMO
Old Feb 3, 2012 | 11:57 AM
carigmbamg's Avatar
Lizardjack, the tank was replaced two years ago under extended warranty (just before it ran out), so hopefully it is not associated with the fuel pumps, but doesn't mean that it couldn't be.
Old Feb 3, 2012 | 01:23 PM
ScottW911's Avatar
I paid an indy $100 to install mine. It turned out to be some of the best money I've spent. It took the pros 2 hours and several devices I did not own, to get to the CPS. The actual fix is easy. The location sucks.
Good luck to you.
Old Feb 3, 2012 | 01:53 PM
W203Ramos's Avatar
'03C32 Obsidian Black, '76Toyota Celica GT TRD, '12R350 4matic Arctic White, '06 ML 350 arctic white
could be anything but we've all gone through this and i'm pretty sure it's theCPS . good luck
Old Feb 3, 2012 | 02:12 PM
lizardjack's Avatar
Shelby GT500
Those two lines above are sufficient for me to come to conclusion that this is the fuel supply issue! If you are confident with your newly installed pump, then check relay, fuse, connector on the rear SAM.
CPS in 99% dies gradually and it always shows it's symptoms when the engine is hot.
Anyway, good luck to you. And please post the results upon resolution.
Old Feb 3, 2012 | 02:26 PM
lizardjack's Avatar
Shelby GT500
Do not take the offence but if you'd have more clues to engine management system you'd never tie CPS to engine load equation algorithm.
CPS is simple gauge that "tells" ECU there and at which phase pistons are located to enable most efficient fuel injection and ignition timing.
It's either work, or doesn't!
Most likely, in your case the technician who you had to install it for you fixed (accidentally) bad connection on the throttle body for example or any other coincidence.
Old Feb 3, 2012 | 05:29 PM
W203Ramos's Avatar
I thought that I read in a post, that if the CPS was bad that it would disable the fuel pump. Is that true? YES pretty much replaced the good old distributor cap + cutting fuel
I have found a Bosch 0261210170 Reference Mark Sensor (Crank Position Sensor) on Amazon for $45.<--cheapper than trouble shooting with a new pump wouldn't you say? even if it is the pump, it's good maintenance.
replacing the cps is a good place to start instead of assuming that your fuel pump is dead or rear sam is melted we try to be optimists here on the forum but based on your description seems plausible that.... cps it is. symptoms have nothing to do with the engine being hot or cold, it just so happens that the car has to be running first in order to experience the symptom....usually.
John
Old Feb 4, 2012 | 08:08 PM
carigmbamg's Avatar
Update, fired up for a second today, but died and just cranked. Flexible 1/4" shafts now delayed until the 11th. So much for good weather to do the job this weekend. Back to tiling.
Old Feb 5, 2012 | 04:52 PM
Beaker's Avatar
2001 C32 AMG
I've had both my CPS go and my fuel pump go, will tell you what happened for both..
CPS - The car would literally just stop in the middle of the road and lose all power. Then it would start up again sometimes the 3rd time sometimes the 30th attempt. I was told the heat did not help trying to restart it but once it started again it usually would be fine again for that entire trip. I got a CEL code reading to know it was the CPS. I drove the car for over a week though even though the CPS was dead but when the car dropped dead randomly in the middle of a highway I had a enough. It probably stopped working 3-4 times, thankfully these were on quiet streets and not major roads.. nothing leading up to when it just stopped and would not crank over again (however it always did 20minutes - 2 hours later at some point)
Fuel Pump - The car again died without warning.. this time though I could not get it started. The car would crank over for 5-10 seconds sometimes but idle very rough, at about 500 not even 700 then just die out. Was obvious it was a fuel supply issue going on.
So from your first post I would 99% say it's a fuel issue and not CPS related.
Old Feb 7, 2012 | 07:30 AM
mbz03's Avatar
W212 2010 Mercedes e350
Cps it happen to me too I did it, it was a pain on the *** good luck
Old Feb 15, 2012 | 04:34 PM
carigmbamg's Avatar
OK, installed the new CPS today and NO luck!
I checked to make sure that I had spark and I was getting spark. Relay for the fuel seems to activate when trying to start. Thinking of renting a fuel rail gauge to check for pressure. Thoughts?
Old Feb 15, 2012 | 10:58 PM
lizardjack's Avatar
Shelby GT500
Just push the needle of valve on the fuel rail. I am sure you will not have any pressure at all.
Old Feb 16, 2012 | 12:34 PM
carigmbamg's Avatar
I did push in the needle and no pressure, but the car was not cranking at the same time. Does the fuel rail stay pressurized? If so, I would agree that fuel supply is the problem. I will check voltage at the pumps and continuity on the pumps.
Old Feb 17, 2012 | 02:19 AM
lizardjack's Avatar
Shelby GT500
If the fuel system works flawlessly, there should be a pressure remained in the line all the time.
